Magnetic ineferencr
848 10 2021-7-1
Trigger2041
Flight distance : 45000 ft
I just goy my mavic 2pro bsck from being rpaired  Both thr aircrsft and RC They tested it and said it worke find
My question is this.  I received a hip replacement and that started the dreaded CHECK ATT MAGNNETIC INTEFERENCE. I also have  a pacrer. 2 metal knee replace and a steel rod in my leg when I groke my femer. WHERE IS MY QUESTION,  EVERYWHERE I GO AND LINK MY DRONE, THE RC SAYS CHECT CHECK APP MANETIC.  Could sconnection?
2021-7-1
Labroides
Flight distance : 9991457 ft
How far are you from the drone when it's warning of magnetic interference?
You would have to be very close to affect the drone's compass.
If you are two metres away, you wouldn't have any effect.
And aren't your surgical bits made of non-magnetic metals anyway?
One other possibility is that the compass is disconnected.
Check the compass data in the Sensors section of the app to see what it says there.
2021-7-1
FloridaNext
Flight distance : 62320 ft
Have you checked the compass status in the GO 4 app in drone menu under Advanced Settings -> Sensor State -> Compass ? Is it still "Excellent" or at least "Good"?
2021-7-1
Trigger2041
FloridaNext Posted at 7-1 04:13
No it is barley red.  It won't lt me calibrate the compass in the horisantal position
2021-7-1
Trigger2041
Trigger2041 Posted at 7-1 16:57
sorry, yes i did.. just 1 red light,   Mean to say it ll calibrate in the horizontal position but not the vertalical positon
2021-7-1
FloridaNext
Trigger2041 Posted at 7-1 17:44
Then I guess you should contact the DJI support. There seems to be something wrong with the compass  hardware chip or so. Keep us up to date!
2021-7-2
Trigger2041
FloridaNext Posted at 7-2 13:58
DJI charges you $149 just to look at it.  Any suggestions on where I might get the compass fixed cheaper
2021-7-16
MedicFL1
Flight distance : 4358570 ft
Surgical stainless steel has never affected  my drones but the rebar in concrete and even if it is near the car can set that off.
I regularly get the compass calibration warnings, but the magnetic interference is usually cleared by moving the drones location a few feet.
2021-7-22
FriedChicken_II
Flight distance : 721555 ft
Hi I wonder if you can let someone else try to spin the drone for you, just for once, to test if it's a hardware issue? Let your friend stand 3 meters away from you or so, and let him do the calibration instead. So that you can figure out if this is a hardware issue of if it's the implants affecting the drone.
If it's not the implant, then maybe you can go back to the guy who repaired your drone and let him fix the chip for you ?
2021-7-22
Trigger2041
FriedChicken_II Posted at 7-22 19:20
Thanks for the tip.  will try that
2021-7-23
kyalami
Flight distance : 17352513 ft
Sweden
Hi there. Had  a friend that got a hip replacement and that was not made of Titanium so he therefore got a small card from the hospital to show at customs when going flying and going trough the metal detector. So having a friend calibrating the compass 3 meters away from you would prove this.
2021-7-26
