FPV Controller V2 No Activation Prompt In Assistant 2 FPV Series
3673 18 2021-7-7
Culuvun
When I connect my FPV Controller V2 to DJI Assistant 2 (FPV Series) on my MAC or PC I never get an activation prompt. I can upgrade/downgrade firmware no problem but can't seem to trigger the activation prompt. When I connected my V2 goggles I got the activation prompt and they're working but the controller never prompts for activation no matter how many times I connect/disconnect to the assistant. Anyone else encounter same situ? Thinking I might have to return the controller.
2021-7-7
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Can you please confirm if you are using the DJI FPV Drone or the DJI FPV Air unit? Please keep us posted so we can provide you an accurate resolution. Thank you!
2021-7-8
Culuvun
Hello! I'm not using either, I just want to use my V2 controller with the DJI Virtual Flight sim (and other PC sims) to practice before purchasing a drone.
2021-7-8
DJI Paladin
Culuvun Posted at 7-8 21:52
Thank you for your response. The said remote controller only requires activation using the DJI Assistant 2 when using it with an Air unit. Therefore, if you are using a standard DJI FPV drone or using it with a flight simulator, you can simply connect it and it is ready to go. Just please make sure that you are using the latest firmware to avoid errors. Thank you!
2021-7-9
Culuvun
DJI Paladin Posted at 7-9 19:38
Thanks that's very interesting. My controller doesn't provide any output when I connect it to my PC or MAC. The device is recognized but there's no detected output from the sticks. Additionally DJI Virtual Flight doesn't connect to the controller. I thought this was probably because it wasn't activated but based on what you've said here it seems more likely I have a faulty controller. I'm gonna return it and get a new one.
2021-7-10
DJI Paladin
Culuvun Posted at 7-10 12:34
Thank you for your response. Please keep us posted once you already have your replacement remote controller. Thank you for your continued support!
2021-7-12
Alvara74
Flight distance : 30364 ft
It must be the controller. It doesn't make sense otherwise
2021-7-12
Alvara74
Oh well, perhaps add that in the manual?
2021-7-12
MHerm
Flight distance : 18845 ft
I'm actually having the exact same issue as the OP and i've read in multiple places that you need to register the product first and that it started registering the input after that in the simulators
2021-7-14
DJI Paladin
Alvara74 Posted at 7-12 05:30
I will take this as a suggestion of yours and forward it to our designated team for attention. Thank you!
2021-7-16
Alvara74
MHerm Posted at 7-14 00:27
Not sure what's going on then
2021-7-16
Alvara74
DJI Paladin Posted at 7-16 01:49
Thank you!
2021-7-16
MHerm
I've also replaced the controller with a new one and same result as before. tried multiple usb cables but without any change. Also tried it on multiple mac's and on an ipad pro but again no change. Note I've no actual drone so I can't "activate" the controller. Thinking about finding someone who has one who can connect my controller to their drone in order to "activate" it.
2021-7-16
DJI Paladin
You're welcome! Thank you for your support.
2021-7-17
MHerm
DJI Paladin Posted at 7-17 22:28
Bit weird that my comments are just being completely ignored by you..
2021-7-18
Alvara74
No problem!
2021-7-19
DJI Paladin
MHerm Posted at 7-16 06:32
Hi there. Thank you for reaching out and sorry for the trouble. Can you please try to download the DJI Assistant 2 software on your PC or Mac and kindly please try to update the firmware of the said remote to its latest one? Also, please keep us posted once you found a user that has a drone and after you activate the said remote controller. Please hit the "reply" button so we notify you when you had responded to us. Thank you!
DJI Assistant 2: https://www.dji.com/downloads/so ... nt-2-dji-fpv-series
2021-7-19
jrstewart83
i know this thread is old but i had to figure this out tonight and didn't find any resolutions online. I had the same issue using the fpv series version of assistant. Use the "consumer drone" version instead and it will activate. Once activated windows saw it correctly and i can play sims. I think the fpv version only works with the fpv v1 controller.
2022-9-3
fansef11fdd9
MHerm Posted at 2021-7-16 06:32
Have you tried turning the controller on when connected as that’s where I failed,  got all working together an got the  goggles an the avata registered but failed with the remote an been bashing facebook groups for info, but then I seen this post an how if using dji drones it wont work as it doesn’t need doing once registered with your other dji products only if using the 03 air unit.
2023-9-20
