Weird connectivity issue
639 3 2021-7-10
Seveance
Hello all, I have a REALLY weird problem. I went hiking to get some shots in, and my drone was not working. Upon further inspection and "Troubleshooting" I have found that the drone will connect to everything, however it is completely unresponsive and says that it is disconnected. Even though the camera is feeding video to my phone, as well as gimble is keeping the camera stable and smooth while I pick up the drone.
I have tried to connect to the DJI program on my PC. My PC discovered the device, however the program is not seeing it to let me reset the firmware. Any ever have this issue?!?!?
2021-7-10
DJI Paladin
Flight distance : 318 ft
Hi there. We're sorry for the trouble. Can you please try to uninstall the DJI Assistant 2 on your PC and redownload it using the link below? Once you successfully redownload the software, please update/refresh the firmware and check if the issue persists. You may also try to sync all your flight records and please try to uninstall and reinstall the DJI Go 4 app on your phone to see if there would be some changes. Please keep us posted. Thank you!
https://www.dji.com/downloads/so ... t-dji-2-for-phantom
2021-7-10
Alvara74
Flight distance : 30364 ft
I don't know what might be the problem here
2021-7-11
Alvara74
Have you tried contacting DJI Customer Support?
2021-7-11
