0Stephan
Flight distance : 451631 ft
Did you try moving the drone closer to the target? Go to an open field if you can, bring the drone to around 5 ft high, and 5 ft from you, and try a quickshot. I've only had high altitude issues when the drone was around 50 feet above the target, and greater. Also, I can't tell if you have GPS signal, but I believe you need GPS to do a quickshot. I can't test the theory right now since my drone drowned, and DJI is in the process of finding a new Spark to send me, but I have done quite a lot of quickshots with different parameters over the last 2 weeks, right before my drone sank. I've only had a height issue once, when the drone was, as I said, a good 50'-100' above the target. |
