Unexpected gimbal tilt when rotating and flying sideways
3939 4 2021-7-31
Honn
Flight distance : 20387 ft
Hey,
the gimbal works perfectly fine when im just flying sideways, cancelling almost any rotation. But as soon as I rotate the drone just a little, the gimbal overcorrects by a LOT. I have no idea, how this could happen, as I just calibrated the gimbal pre-flight and I am not in FPV-mode. Are there any settings to prevent this behaviour?
Thanks
Honn
2021-7-31
Roy Jansen
Flight distance : 66978 ft
@Honn, there are some great 'smoothing settings', both for the movements of the DJI Mini 2, but also the camera gimball. I truly advice you to watch this video:
I'm sure you're a littebit more satisfied now. Also, try to shoot your videos in 'Cinematic Mode'. Use "normal or sport mode" when you know your drone a little bit more. (These are simply more powerful, but requires some good movements in flying your drone)
If the problem is still there, i advice you to slowly clean that Gimbal with pressured air, maybe there's some little sand or dust? I hope your little buddy will listen now.  Peace.
2021-7-31
Bashy
Flight distance : 2354357 ft
Are you saying the gimbal produces a tilt when looking certain ways or that the gimbal seems to tilt (like a wobble) during the rotation?
It could be that you're in sports mode  perhaps or perhaps its too windy, if it does it again, try to see what mode you're in, if there are any wind warnings on screen. See if Cine mode makes any difference as its slower on rotating?
2021-7-31
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please send us a video sample showing the issue for better assistance? Please keep us posted. Thank you!
2021-7-31
Honn
Fortunately, i found the problem. I accidentaly double-tapped the 'Function'-Key and it switched to FPV-Mode. Thanks for your help anyways.
2021-8-1
