M300 BVLOS, Mobile van operation.
1021 4 2021-8-24
fansc970c377
Flight distance : 635469 ft
South Africa
Good day all.
I am looking to operate the M300 from the inside of a van. Picture this, a panel van that has two monitors, inverter chargers and internet connection. The idea is to control the drone from inside the van with the doors closed whilst doing search and rescue operations.
Now we would want to fly a good amount of distance from the van however this would be drastically reduced due to the fact we are enclosed in a metal van. What solutions are there to be able to have the controllers antenna mounted on the vans roof?
Any ideas are solutions?
Personally I think there should’ve been an external antenna accessory with a long cable and possible booster the could be purchased for these type of operations.
TIA
2021-8-24
fans5b25584c
Flight distance : 24012 ft
Mount the R/C controller on the roof under some sort of plastic rain/sun cover with a USB cable run below to a tablet for control and HDMI cables for video? You probably need to be able to jump out and get the R/C unit in an emergency to hit "Return To Home" if something happens to the control tablet down below.
2021-8-25
IBV Bob
Flight distance : 123707 ft
Sweden
I'm controlling the M300 from our mission van. This brings several advantages. We then output to a 55" screen via HDMI.
The antennas are connected via N- connectors ( thick cables)
To a modified controller mounted on a rack table.
2021-9-9
IBV Bob
Sweden
Our antennas are mounted on the roof withe magnets or quick lock for the directional antennas.
2021-9-9
IBV Bob
Sweden
You can boost the signal. I prefer N connectors. SMA is too fragile for the thick cables and these you need if you want to minimize dampening your signal.-eapecially Rx
2021-9-9
