Car charger - a slightly different idea ...
1989 15 2021-9-5
frankymusik
Flight distance : 27904331 ft
DJI (and some other accessory manufacturers too) offer very special car chargers for the different drone batteries. These loaders have surely made some friends ...
But, such a car charger is only suitable for one specific battery type!
In the post ...
   https://forum.dji.com/forum.php?mod=viewthread&tid=248443
a user describes his bad experience with these chargers.
But then DowntownRDB brings in his personal experiences, and I have also gladly implemented it:
There are very cheap and very universal DC - AC converters that have been specially developed for car batteries and that generate an AC of 110 V or 220 V.
The advantage: The chargers supplied by DJI for "home use" can now be used, and special chargers are no longer required!
There are two (quite different) types of such converters:
1. "Modified sine" converter
2. "Pure sine" converter
While the first generates a kind of "square-wave pulses", the second one really delivers a very good sinusoidal alternating voltage.
Both work very well with the DJI chargers.
The "modified sine" converters cost about half of the "pure sine" converters.
I "examined" the output voltages of these converters with a connected DJI charger, viewed them with an oscilloscope. Everything looks as expected.
In the end I decided on a "pure sine" converter because I wanted to be absolutely sure that it is suitable for all possible cases, even if, for example, you want to connect a device with a real "mains transformer" ...
Of course, such "old" power supplies (as "mains transformer") are rather rare these days, but I was still so impressed by the beautiful sine wave shape that you can hardly go wrong with it!
The "smallest" such DC - AC converters can generate approx. 300 W "mains output". In any case, this is sufficient for the stated purpose. You actually need a maximum of 100 - 150 W ...
Final remark:
Depending on the country in which you live, you have a mains voltage of 110 V or 220 V.
The DJI chargers work universally, i.e. both at 110 V and 220 V!
For this purpose you can always buy a 12 V to 110 V converter without hesitation. The efficiency is then even a little better, because you don't have to generate the higher AC first ...
Nevertheless, you should look carefully that the appropriate AC socket is installed on the converter, otherwise you will need an additional adapter plug!
Here are a few more links:
I have had very good experiences with this one:
https://www.amazon.de/gp/product ... 0_s00?ie=UTF8&psc=1
DowntownRDB drew your attention to this one:
https://www.amazon.com/BESTEK-In ... =1629720838&sr=8-12
Maybe that will help one or the other ...
Many greetings
Frank
EU plug
EU plug
US plug
US plug
2021-9-5
alex_markov
Flight distance : 39646480 ft
Bulgaria
I use this one https://www.amazon.de/gp/product ... 0?ie=UTF8&psc=1
after several other not so good ones - and am very happy even have a second "wall" charger for the car with the hub and never run out of batteries ;)
2021-9-5
DJI Stephen
Hello there frankymusik. Good day and thank you for sharing these information and your insights with regards to this matter. Have a safe and a happy flying always.
2021-9-5
frankymusik
alex_markov Posted at 9-5 11:52
I use this one https://www.amazon.de/gp/product/B00JGJL4ZQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Hi alex_markov,
I had also tested exactly the one you describe ...
It is a "modified sine" converter, so it delivers a square-wave output voltage. This still works very well with the DJI chargers, but I had "certain" concerns (... see my description above) ...
2021-9-5
frankymusik
Excuse me!
A double post within the same forum ...
2021-9-5
alex_markov
Bulgaria
frankymusik Posted at 9-5 22:50
Hi alex_markov,
Works fine for me
2021-9-5
DowntownRDB
Flight distance : 1722 ft
Very detailed write up frankymusik.
2021-9-6
frankymusik
DowntownRDB Posted at 9-6 06:10
It's your brilliant idea that you have to come up with first of all ...!
Many thanks!!!
2021-9-6
frankymusik
Double post, but not from me ...
Maybe from an administrator ...?
2021-9-6
frankymusik
2021-9-6
frankymusik
2021-9-6
frankymusik
2021-9-6
frankymusik
2021-9-6
The Saint
Flight distance : 5902228 ft
i have 2 of these and took both on a 7-day road trip me...and never used them; they came back home with 100% charge.  great idea but as long as you have the very occasion access to a wall plug and you have a fair amount of batteries and you're not going to try to fly your drone all day long....just never needed them.  good for backup and emergencies....but next trip, i will only take one.  a single dedicated vpa was more than sufficient.  that has been my experience.
2021-9-6
Bashy
Flight distance : 2354357 ft
Thanks for the info, seen as i already have a car charger for the P4P, I went for one of these for the Mini 2 seen as its USB Coops, not sure why I thought this was the Mini 2 section, sorry, carry on...
2021-9-6
DowntownRDB
frankymusik Posted at 9-6 08:10
Many thanks!!!
You're very welcome.    Have a great week.
2021-9-7
