speed
554 6 2021-9-22
djiuser_M9DApMHCHY1H
Flight distance : 2081280 ft
Portugal
Mini 2 sometimes the maximum speed in N mode is not more than 28km/h. Why?
2021-9-22
Bashy
Flight distance : 2354357 ft
Perhaps too low to the ground?
2021-9-22
Portugal
Bashy Posted at 9-22 04:10
Is it normal for this to happen near the ground? The mini 2 the maximum speed in N mode is 36km/h. The mavic mini reached fast 28km/h
2021-9-22
djiuser_nO2RdSW5BSUg
Flight distance : 80646017 ft
Poland
Lower the gimbal more than -5 degrees. From 0 to -5 degrees and at -90, the speed is lowered to 8 m / s.
2021-9-22
robpri
Flight distance : 635066 ft
South Africa
Even the slightest of wind can effect the true speed. Try flying in all directions and check again
2021-9-22
JJB*
Flight distance : 12401030 ft
robpri Posted at 9-22 05:58
Only head wind has effect, too much wind and the speed will not reach it maximum.
With tail wind the max speed is controlled by less forward pitch to keep speed at its default max speed.
Cheers
JJB
2021-9-22
DJI Stephen
Hello there. Good day and thank you for reaching out. The DJI Mini 2 has a Maximum Speed of 16 m/s ( S Mode ), 10 m/s ( N Mode ), and 6 m/s ( C Mode ) ( near sea level, no wind ). Thank you.
2021-9-22
