DJI Assistant 2 (Enterprise) Vision Calibration - Screen Size Error
4438 4 2021-10-6
Ewan.AC
I have been trying to calibrate the vision system on an M2 Enterprise Advanced through the DJI Assistant App on a Windows laptop. Every time I complete the calibration process, I get an Error Message stating there is a calculation error to do with my screen size. I have tried entering my screen size and my screen resolution in the box, but when I restart the calibration process I cannot proceed, the video output of the drone is no longer displayed in the bottom left of the screen.
To try and solve this issue I have reinstalled the app multiple times, as well as trying different monitor resolutions, neither of these solutions worked.
What else can I try to fix this issue?
Error Message
Error Message
2021-10-6
DubSound
Flight distance : 104459 ft
I don't suppose you have a curved monitor installed by any chance? If so; I find that I get this when I have a curved monitor set as my primary monitor. When this popup comes up however entering the resolution does nothing. I'd see if you can either set a flat monitor as your default monitor, restart DJI Assistant 2 and try again, if it still happens you may have to disconnect the curved monitor entirely until after you've finished calibrated. That IS if you have a curved monitor set up, if not it's another issue entirely
2021-10-6
Ewan.AC
DubSound Posted at 10-6 03:50
I'm trying to calibrate on an HP Laptop with no external monitors connected. Thank you for your response though.
2021-10-6
DJI Stephen
Hello there Ewan.AC. I am sorry for the trouble and thank you for reaching out. You may give a try to change the resolution of your screen for your reference you may take a look at this information. It is recommended to use a monitor with a size of 14 inches or more, and a curved screen is not supposed to be used. Set the display resolution to the recommended value (usually 14 inches for 1366*768 or 1440*900; 17 inches for 1366*768 or 1280*720; 19 inches for 1366*768 or 1440*900; 22 inches for 1680) *1050 or 1920*1080; 24 inches for 1920*1080 or 1920*1200). Thank you.
2021-10-6
djiuser_kPcJYW531mYG
Tunisia
DJI Stephen Posted at 2021-10-6 18:52
the calibration process don't progress
i changed the resolution but it didn't work
no green rectangle or red rectangle appears
even the camera view on the left corner don't show anything
2022-3-7
