AlansDronePics
Flight distance : 814751 ft
Guernsey
Having recently bought an all electric car, battery life becomes the major topic when it comes to replacement cost. The point is, the battery tech is the same for car, laptop, torch or drone.
Research shows that lipos degrade rapidly when fully charged compared with a partial charge of between 20% to 80%. Between those values, the chemistry behaves in a less aggressive way.
Typically, you would fully charge the battery just before flight. Ie. Within an hour or so. Sometimes circumstances prevent the flight and to avoid shortening the battery life, auto discharge kicks in.
Lipos last longer if discharge is gentle and the sooner the charge reaches 80% the better for the cells.
You can damage the cells irreparably by dropping below 20%. The lower you go, the worse the damage.
Some electric car manufacturers, some top range laptops and critical equipment are designed never to actually charge beyond 80% or discharge below 20%, even though the displayed charge is 100% or 0%. |
