fans5b25584c
Flight distance : 24012 ft
I use an M300/P1 combination for low resolution (non-RTK) surveys of island erosion, ground cover, counting wildlife, etc.
We fly mission grids, then use Photogrammetry to generate an orthomosaic or DEM, doing our counting and polygon generations in a GIS Program or Google Earth.
First off, it sounds like you're using single images if you want the EXIF data, but that must be difficult to fix a single location, and I'm really interested in how you get altitudes from a single image, even given the altidude of the UAV.
If you were to use a Photogrsmmatry program, for each location you would get the average of the EXIF and altitude calculations for several images, which I would thikn would ome out to be much more accurate.
At that point you can set the photogrammetry software to export points in any format or datum you can think of.
If you're using a P1, though, the amount of infomation associated with each picture is magical...
