Is the purple haze gone ?
732 19 2021-11-23
hallmark007
Flight distance : 9827923 ft
02A2BF00-ACCA-4FF9-86E8-3CA00D6CB57B.jpeg D9C438E4-C04A-43F5-8CB7-628470CA8D75.jpeg This is both ends of the spectrum sky colour is different as these are opposite ends of the beach which is 5K long. When looking at my screen I can see a strong purple colour in the clouds but in the raw photos its not there so much but it still seems to be there, its a bit odd. Photos above have been edited only very little in PS.
2021-11-23
Nicodema
Flight distance : 90259 ft
Can't see any obvious magenta cast. Saturation seems pretty amped though. What does the original DNG look like? Are you saying you saw purple on the phone/RC Pro screen? Sorry, not quite clear from your post.
2021-11-23
goldenorfephoto
Flight distance : 3405390 ft
my images are not showing any colour cast , have you darkened the sky in post?
2021-11-23
hallmark007
Nicodema Posted at 11-23 10:16
There is no saturation added, yeah I can see it on the screen and I expected to see it in the photos, I brought both up to 15 dehaze  something I never do . But I’m starting to think I’m imagining it.
2021-11-23
hallmark007
goldenorfephoto Posted at 11-23 10:34
The top one is slightly darkened, but basically I just reduced highlights increased shadows slight noise reduction and Dehaze which will darken skies a little but thats about it. I think I’m trying to be convinced that its not there. I’m not unhappy with them and skies around here change so much .
2021-11-23
Blériot53
Flight distance : 6188465 ft
Purple? No. Colour doesn't look quite natural though - might be my screen settings of course.
2021-11-23
DJI Stephen
Hello there hallmark007. Good day and thank you for sharing these aerial photos that you have taken using your new DJI Mavic 3. Nicely done and have a nice day.
2021-11-23
GaryDoug
Flight distance : 1264639 ft
"But I’m starting to think I’m imagining it."
I see nothing unnaturally purple there. Have you been toking on the Purple Haze again ;-)
Excuse me while I kiss the sky!... God Bless Jimi!
2021-11-23
Chest Rockwell
LOVE the top picture, very dynamic.  The tint might be a little green for my taste but maybe that's what you saw in person.  I don't see any purple there at all.  On the bottom one, MAYBE a little at the horizon on the right side, but this is far from the most egregious example.
In my videos I've determined that shadowy areas seem to push red colors towards purple.  A slight adjustment of the red hue in Premiere back towards red fixes it right up.  It will be interesting to see if DJI ultimately decides this is a universal issue and releases a firmware update, or if it is determined to be a hardware defect in some units.
2021-11-23
Montfrooij
Flight distance : 2560453 ft
So it is not in the DNG files?
2021-11-23
FB: GeoDrone4K
Flight distance : 2676129 ft
Romania
For a man who "knows" things, you disappoint DJI...what do you mean Purple?
DJI drones are the best...and you have a half made drone, what do you expect?
(Now, that is your type of reply, one you give to others...it sucks to see how nasty is to get one from others, no?)
But as we are gentleman's, I will give you a very simple way to check it:
1. Take the picture in Lightroom or any other program that have a very good waveform/spectrometer.
2. Select portions of sky and check histogram...
3. If you see a difference in magenta/purple specter, there it is, you have a problem.
You don't need to "see" the differences, as this is amateur approach...You need to look at histogram for each color/waveform...and you will see if there is extra purple in DNG...(because the JPG is not a reference, as you know, only DNG is a reference).
Good luck, and next time you harass members that have problems with DJI products, remember this: It can always happen to you too  )))).
2021-11-23
FB: GeoDrone4K
Romania
PS. In second picture is very obvious a purple haze on right side and a small one in left side....don't know if it from your edit or is just the compression algorithm from DJI for JPEG, check DNG.
2021-11-23
hallmark007
FB: GeoDrone4K Posted at 11-23 23:57
Believe me I’ve seen some stuff you’ve posted here on this forum and I don’t need your advice. Go sort your own stuff out.
2021-11-24
hallmark007
GaryDoug Posted at 11-23 19:48
I think I have, and its more to do with so many conversations , also on Monday I set 220 Amethyst in 42 rings so purple is on my brain this week.
2021-11-24
hallmark007
Montfrooij Posted at 11-23 23:55
No its not , not anymore than you see above.
2021-11-24
Montfrooij
hallmark007 Posted at 11-24 00:20
Exactly, I did not notice.
But is it still in the JPEG, or was that fixed too?
2021-11-24
hallmark007
Montfrooij Posted at 11-24 00:23
It definitely looks on my screen like its there and from what I remember looking at jpeg it was there but not as strong, I will check these later again I’m not near my computer.
2021-11-24
Montfrooij
hallmark007 Posted at 11-24 00:31
It is strange when they introduce this in the jpeg engine.
However, if you are using adobe products, they have some autocorrection on DNG files that include a lens profile.
Not sure if that also will correct for these things.
2021-11-24
hallmark007
Montfrooij Posted at 11-24 00:33
I’m not seeing it as a major problem and tweaking their system will hopefully put it right, but if it was a lens issue which some are saying then that would be a problem. Dji have said they’re looking at it so ill wait and see what develops (pardon the pun)
2021-11-24
GaryDoug
I envy you for doing spectacular images of your country. I will never get that good because i am too impatient and love fast action video instead. Hope you understand. Different birds of a part-Irish feather I guess ;-)
2021-11-24
