dr6583
Flight distance : 490627 ft
sduck Posted at 11-25 19:39
While DJI says it's not supported, it most certainly works fine on macs running the latest OS softwares. It runs fine on my 2017 macbook pro running Big Sur 11.6. I suspect they say it's not supported because their one mac guy doesn't get any budget to keep updated and hence can't test things adequately.
As far as installing it, start the installation like anything else, and when you get the security error code, click cancel or ignore. Then open system preferences>security and privacy, look on the "general" tab, and in the bottom pane there should be a repeat warning, but with an option to "open anyway?" - click yes, and then open, and the installer should start again.
Thanks for the tip, but in the OP it states I already checked that :-). And if your still on 11.6 you are not on "the latest OS softwares."
disclaimer-- I am a Mac Advisor for Apple Tech Support, just coincidence!
