frankymusik
Flight distance : 27904331 ft
kabauterman Posted at 12-20 11:56
It sounds like you never used a camera before or always fly in Auto Exposure...
If I would always fly in Auto I would also never mind about the Wheel or Missing Features I called out in my post.
... the M3 is my first drone that has an adjustable aperture. So I got used to shooting with a fixed aperture ...
It was always "a lot of work" to select the right ND filters before the flight ...
It is now wonderful that only a "rough estimate" of the ND filter is sufficient, and then the "fine adjustment" can be made in the air using a variable aperture ...
Since I mostly film (in the air), I don't have to constantly adjust the aperture.
I have the option of exposure correction using the 5D button, to the left or to the right. This is also very helpful (as far as I know it doesn't work with the standard controller, so only via touchscreen ...).
As I wrote before, I think the possibility of adjusting the aperture using the right wheel while pressing C3 at the same time would be very useful ...
Both controls with the right hand, that's pretty comfortable, isn't it?
Firmware is generally "made" in such a way that all hardware elements (buttons, wheels, touchscreen gestures, ...) are reported "to the top", i.e. to the "layer" above, in this case to the Fly app ...
Therefore, the Fly App can then determine that, for example, C3 is pressed and the right wheel is being adjusted ...
Now the Fly App can forward the same command to the M3 as if the touchscreen were operated to adjust the aperture!
There is no need to develop a new RC Pro (2) for this! The hardware (and probably in this respect also the firmware of the RC) are already able to carry out this function ...
The Fly App, however, still needs this "small" extension ...
So I see no reason to "condemn" the RC Pro, to deny it any "prosumer" quality.
The Fly app will definitely see further improvements, but it will certainly not mutate into the Go 4 app .....
You should be aware of this if you opt for the "consumer drone" Mavic 3 and spend a lot of money on an additional RC ...
That is the "long version" of my statement: send back if you don't like it at all ... |
