Mavic pro controller sn worn out. Where to find in app?
685 9 2021-12-19
IRMMZ 1
Flight distance : 221371 ft
The sn of my Mavic Pro controller sn is worn out on the label. Where can I find it in the app?
2021-12-19
Sean-bumble-bee
Flight distance : 15997 ft
Copy a txt flight log off your phone, down load the program CsvView from the web, process the log with CsvView. The controller sn might be shown on the resulting summary window.If not, click on whatever is the tab in the upper left  of that resulting window/page and export a csv of the log to wherever.
Open the csv with a modernish spread sheet program and search the title row for RCsn or similar or scroll across to near the RHS of the spread sheet.
Various sn are listed in two sets of columns towards the RHS. The Rc sn is one of these serial numbers it may appear twice, once in each set.
Look in columns 237, IC & 265, JE
With a Mavic 2 I sometimes do not get the controller sn recorded in the log, I have a suspicion that happens when there is a mismatch between firmwares on the drone and controller but that is guesswork.
You might also check the outside of the original box, I think I have seen the RC sn on the outside of a Phantom 3 box.
2021-12-19
yogi053
Flight distance : 26104915 ft
Is it not recorded in the controller's menus under the 'about' details?
2021-12-19
Sean-bumble-bee
yogi053 Posted at 12-19 10:49
Duuuuh I forgot about that lol
2021-12-19
DJI Stephen
Hello there IRMMZ 1. Good day and thank you for the inquiry. Since the serial number of your DJI Mavic Pro remote controller is worn out. Kindly please check the DJI Go 4 application under the about " About " tab for you to be able to check the remote controller's serial number. Thank you.
2021-12-19
IRMMZ 1
Under the about tab, I can only find the main board sn of the drone. Not the controller.
2022-1-23
Mobilehomer
Flight distance : 18135846 ft
The about tab in the camera view.
2022-1-23
Sean-bumble-bee
Try the suggestion in post #2
2022-1-23
IRMMZ 1
Mobilehomer Posted at 1-23 10:03
No, not there
2022-1-23
Mobilehomer
My bad, I'm thinking Fly app.
2022-1-23
