Can i switch on Mavic 3 folded and with strap on to transfer vide...
3387 9 2022-1-8
Dury
Flight distance : 179150 ft
India
Till now i just unfold the full drone and switch on to transfer videos. can i just transfer without unfolding and with safety strap on ?
2022-1-8
Mobilehomer
Flight distance : 18150351 ft
Yes you can. But remove the gimbal protector, as it goes through gimbal calibration when you first start it.
2022-1-8
Sean-bumble-bee
Flight distance : 15997 ft
In addition to the above, do not have the drone sitting on anything whilst the props are doing their twitch thing (if the the M3 does that).
Do folded arms block ventilation slots?
I don't have an M3 but if I intend to have a drone switched on for a while and not flying I raise it, using books etc. under the undercarriage, and direct the output of a fan at the drone. It may not be necessary but it wont do any harm.
2022-1-8
Labroides
Flight distance : 9991457 ft
Just pop the SD card, put it in a USB adaptor and put that in your computer.
That will be faster and less complicated to using a cable and powering up the drone.
2022-1-8
Dury
India
Labroides Posted at 1-8 16:17
I have the cine version in which the SSD integrated.
2022-1-8
Dury
India
Sorry to forget to add . It's a cine version where the SSD is integrated.
2022-1-8
Labroides
Dury Posted at 1-8 16:45
Sorry about that.
The cine version is a disaster of poor design.
Unless you really need ProRes, shooting  H265 and saving to an SD card would be a much better solution.
2022-1-8
Sean-bumble-bee
Just as matter of interest would it have been possible to make the Cine's SSD removable or 'powerable' by USB without powering up the drone?
2022-1-8
Labroides
Sean-bumble-bee Posted at 1-8 19:02
No ... it's not
2022-1-8
GaryDoug
Flight distance : 1264639 ft
I would not leave a drone folded with power on for more than a few minutes because of ventilation issues. The M3 has a cooling fan. I assume the file transfer takes longer than that. Also, the M3 doesn't wiggle the props that much at power up and I routinely leave the camera protector on even though I know it fails the self test.
2022-1-8
