Mini 2; One Tough Little Bird
508 4 2022-1-15
fans5fad8194
Flight distance : 8320997 ft
I was filming at a little park in Roslyn NY. I was flying backward and lost my orientation of where the drone was. I didn't realize it was flying into a hillside. I decided to initiate RTH to bring the drone back closer to my location and watched with horror as she flew into the tree. Much to my surprise (and immense relief) she continued flying albeit with the gimbal pointed straight down. Miraculously she continued RTH right back to me. The only damage was a cracked prop which I replaced on the spot and she flew again with no apparent ill effects.
As Forrest Gump said "Stupid is as stupid does." This is almost exactly how I lost my Mini a year ago.  I hope I have learned my lesson about flying backwards - at least until I upgrade to one with collision avoidance.
John
2022-1-15
Sean-bumble-bee
Flight distance : 15997 ft
Did you replace both blades on the affected motor? They are likely to be balanced pairs. If you fly out somewhere and pass close by or behind an object that is higher than your current RTH setting it is advisable to reset your RTH height to higher than the object, measure the height of the object with the drone then add 10m/30ft or so and use that height as the new RTH height.
2022-1-15
DAFlys
That was lucky.
2022-1-16
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We're glad to know that there is no major issue that happened in your unit during the incident. We strongly recommend replacing all the damaged propellers on the unit to avoid any issues when you fly again the unit. Also, please pay attention to the application if it does show an error message regarding the motors, please don't hesitate to reach us. Thank you for your valued support.
2022-1-16
Montfrooij
Flight distance : 2560453 ft
Nice that you got it back!
2022-1-30
