Mark The Droner
Flight distance : 2917 ft
Hi again,
Yeah that's a straight P2. I saw your post on the other site. I've never owned a straight P2 and know nothing about the zenmus gimbal other than very very few people use it these days. That Immersion device you mentioned is an aftermarket product for the FPV which, I believe, should be 5.8 ghz so that it doesn't interfere with the controller freq. And I believe its purpose is to relay the FPV signal while making it stronger. So yes, it extends the range of FPV. Without it, your FPV range would only be a few hundred feet at best. As far as extending the range of the drone itself, the device won't help you, but you can do other things to extend the drone's flying range as mentioned above.
To learn more about the Immersion device and that gimbal, you'd probably be best off searching and reading old 2014 posts on the other site. Lots of great info there if you're willing to spend the time to tap into it. And that's fine if you're a retired hobbyist who has time to burn and enjoy this kind of thing.
OTOH, if you just want the drone to work correctly and fly, you'd probably want to acquire something more up to date.
Here is your user's manual and some other goodies. Phantom 2 - DJI
Good luck!
