Cannot take off - Insufficient GNSS satellite signal detected.
1817 14 2022-2-19
RafaelB
Dominican Republic
Hi, I need help.
I have an Agras MG -1P RTK and suddenly it shows me this message "Cannot take off - Insufficient GNSS satellite signals detected. Aircraft has switched to Attitude mode. Fly with caution."
I present it for no reason, I have not had a recent accident and the last one I had was more than a month ago and then everything was working fine.
I already tried with different batteries, checking the connection of the compass, reinstalling the firmware and everything is fine, but it keeps presenting that message and it does not allow me to take off.
Who can help me please?
https://forum44.djicdn.com/data/attachment/forum/blob:file:///24dd7ea5-7504-4a4e-8626-44d3b054c533
2022-2-19
fans246c8e8b
Did you happen to damage the rtk antenna module located near the locking arm bolts?
2022-2-23
RafaelB
Dominican Republic
I don't know, so far I have only used the drone with GNSS, I don't have the RTK bars.
Does this drone use the RTK antennas to connect to the satellites?
2022-2-23
RafaelB
Dominican Republic
fans246c8e8b Posted at 2-23 10:31
2022-2-23
fans246c8e8b
In your picture above, right where the two arms meet, there is a plastic black stub that is pointing upward. That is your rtk antenna module. If there happened to be damage to one of those, the drone will not connect to GNSS.
2022-2-25
fans246c8e8b
If you need clarification of what the rtk antenna is, look in the manual at the diagram of the drone. I believe it is item number 31 or 32.
2022-2-25
RafaelB
Dominican Republic
fans246c8e8b Posted at 2-25 22:47
You're right, check the antennas, it smells a bit burnt, when I uncover it, it shows that it is overheated.
What should I do?
2022-2-26
fans246c8e8b
Purchase new rtk antenna modules. You shouldn’t need the rtk antenna base, only the top portion. Many distributors do not have this part readily available and will tell you it must be ordered from distributor in China and will take a month for delivery. Hopefully you can find distributors in your area that has a good inventory so you don’t have to wait. Make sure to send good pictures to distributor describing exactly what parts you need so they get the right one ☺️
2022-2-26
RafaelB
Dominican Republic
fans246c8e8b Posted at 2-26 11:45
I'll get to that right now, thank you very much, you're very helpful.
2022-2-26
fans246c8e8b
Sounds good. Happy to help. Let me know if you are able to get it going. Also, where are you from if you don’t mind me asking?
2022-2-26
RafaelB
Dominican Republic
fans246c8e8b Posted at 2-26 22:52
I'm already looking for the piece, I'm worried about the time it may take, I have clients waiting. I am from the Dominican Republic.
2022-2-27
fans246c8e8b
Ya, there doesn’t seem to be many distributors there. You might want to try a company located in the USA called rantizo. They may have the parts you’re looking for or quick access to them. They might even have the option to speed up your delivery.
2022-2-27
RafaelB
Dominican Republic
fans246c8e8b Posted at 2-27 22:11
Excellent, thank you very much, I just sent you an email.
2022-2-28
RafaelB
Dominican Republic
Thank you very much for your help, I already put the part on the drone and it is working perfectly.
2022-3-16
fans246c8e8b
Awesome, glad to hear that.
2022-4-3
