H264 vs h265
4788 12 2022-2-23
djiuser_co43r6PJI8ux
Flight distance : 1851703 ft
When I record in h264 plays fine on my  laptop  which is 4 years old h.265 won't play. But on my Samsung s8 plays everything even panno 360 .is there any benefits difference between them. And how does it change the frame rates depending on where in the world you are. EU don't have 60fps in Australia we don't have all of these restrictions.
2022-2-23
DJI Stephen
Hello there. Good day and thank you for giving out these information. The advantage of the H.265 video codec is that the HEVC ( H.265 ) is a more modern video codec than H.264. It retains more details and uses less storage space. Thank you.
2022-2-23
spetersen
Flight distance : 501952 ft
Thailand
Most likely your computer is not powerful enough. I had the same problem a year ago with my MacBook Pro 2015. When I got a new MacBook Air with M1 the problem disappeard . I can't say what is required on a Windows based PC but I'm sure others can give you some guidance . Good luck.
2022-2-23
gpsmikey
Flight distance : 11473 ft
You don't say which version of windows you are using, but the HEVC codec is not in win7 and is an add-on for windows 10 (ran into this a while back with my Western Digital surveilance cameras).  H-265 uses the HEVC codec for the video.
2022-2-23
gpsmikey Posted at 2-23 21:44
Hi im using Windows 10 .
2022-2-23
djiuser_co43r6PJI8ux Posted at 2-23 21:46
Might updated computer. Also Thankyou for letting me know. Cheers from Sydney Australia.
2022-2-23
dji_MODDER
Flight distance : 73209 ft
Vlc-player should have h265 codec
2022-2-24
DAFlys
You can use handbrake to convert h265 to h264.   H265 only works well on the latest hardware.
2022-2-24
wa.jesse07
Flight distance : 4686545 ft
The reason why it isn’t 60 is because the power is weaker in AU. That is also why It doesn’t go as far.
2022-2-24
AntDX316
Flight distance : 3394731 ft
DJI Stephen Posted at 2-23 20:18
but is this retains more information for "editing" flexibility? H.264 and H.265 should look Identical until stretched on the colors, highlights, shadows, etc?
2022-2-24
wa.jesse07 Posted at 2-24 09:31
Hi thanks for the info but im not understanding what you mean by more power  .so if i bring my air 2s to England would it operate like it does in Australia as in distance.
2022-2-27
Westwind77
Flight distance : 567234 ft
When you say it will not play does that mean at all or studders a lot during playback? I have a higher end desktop that had no issues with 4k 265 at any frame rate, but the minute I jump to 5.4k it studders and can't handle the playback, at least in Davinic - it is fine in the typical windows media player.
2022-3-3
djiuser_Mp1lqWkl7qzv
India
Please install latest video codecs on your machine and H265 videos will play without any issues. Or just install VLC which will install videos along with it.
1-24 19:28
