IMU and Compass redundancy?
3076 31 2022-4-5
Vantage_DS
Flight distance : 5991309 ft
I'm having a hard time finding this out via google, so thought best to just ask!
Does the Mavic 3 have dual IMU and dual compass for redundancy?
Thanks in advance!
2022-4-5
Suren
Flight distance : 13498560 ft
New Zealand
I don't think it does.
2022-4-5
Samakopita
Banned
2022-4-5
Vantage_DS
I should have expected that!
I can't believe this info is so hard to find though
2022-4-5
Yaros1
Flight distance : 19981112 ft
Samakopita Posted at 4-5 11:17
And clearly no GPS redundancy. Only half a GPS unit.
Exactly
The issue with GPS is a big one… I suspect it is hardware issue.
2022-4-5
Sean-bumble-bee
Flight distance : 15997 ft
Ouch,
2022-4-6
StanMaster
Banned
2022-4-6
Yaros1
**** The author has been banned or deleted automatically shield ****
OMG, User banned??
For what?
2022-4-6
Flormo2002
Flight distance : 12425794 ft
Yaros1 Posted at 4-6 05:09
OMG, User banned??
For what?
Where have you been? Lol
2022-4-6
Yaros1
Flormo2002 Posted at 4-6 05:16
What do you mean?
2022-4-6
DH_Pilot
Flight distance : 328084 ft
Slovakia
IMU module have 4 gyroscopes from which only one is in use so according to my opinion there is some kind of redundancy. Unfortunately since mavic air if I remember correctly they are using only 1 compass instead of two like on old Mavic Pro. There were no dual compass configurations after Mavic Pro I think.
2022-4-6
Sean-bumble-bee
OMG, User banned?? For what?
trolling, spam, offensive content, off topic........take your choice.
2022-4-6
Vtcats
Flight distance : 199518 ft
I tried to create a new thread, but for some reason it’s not showing up in the forum, so given its a “similar” question to this topic, I thought I’d ask here.
What’s the consensus for calibrating the compass and/or IMU:
1st) upon receiving it new and before first flight
2nd) upon traveling across the country?
OR, only when prompted?
Years ago with the original Mavic Pro, I was prompted for comoass calibration before my first flight (which I did), and never was promoted again. And never was promoted an IMU calibration
2022-5-4
hallmark007
Flight distance : 9827923 ft
Vtcats Posted at 5-4 10:04
There is no need to ever calibrate compass, unless prompted to, and this will almost never happen . You may get a prompt to move or calibrate, always move and try again.
Tip To Help Avoid compass interference and crash.
1/ Never calibrate Compass unless prompted to. Your compass will always prompt to calibrate if it needs it .
2/ start AC leave until you receive enough gps lock ,
3/ if you get Compass interference turn off AC and move to another location,
without interference.
4/ In bottom left hand corner on your map you will see small red/blue triangle, check to make sure that this triangle is pointing in the same direction (heading) as your AC, this will show good compass on the ground.
Raise AC to height of 8ft
Hover for 20 seconds
Fly forward 2ft
Backward 2ft
Left 2ft
Right 2ft
Up 2ft
Down 2ft
Yaw left
Yaw right
Each time returning to hover position
If you have a good horizontal each time, you will then know you have good GPS good IMU and good Compass, and your ready to fly.
This exercise takes less than 2 minutes and is worthwhile doing before every flight,
2022-5-4
Vtcats
hallmark007 Posted at 5-4 10:41
Good info thanks. I USED to do that way back with my Mavic pro, but have never had an issue so Ive become somewhat lazy (now that it’s not worth much anymore). Although I  do check the compass is green every time. But glad you’ve written out this process again as it very specific to see if any issues and I won’t feel under the gun as much with so much more flight time compared to the MP.
2022-5-4
HedgeTrimmer
In my experience, there is no need to calibrate drone compass, unless system calls for compass calibration or you notice drone's compass heading is off from drone's true heading.
** Adding following point made by Labroide: Move to another area and see if system still calls for compass calibration or drone's compass heading is off.
In such possible interference cases, I would suggest turning drone off, moving to new takeoff point, and turning drone on while it is in air.  Thus putting at least 1-meter distance between drone and possible buried source of magnetic interference (like hidden metal piping or burried trash with metal).
However, DJI has in passed stated: "First, when flying at a location father than 10 km away from the last  flight location. Second, the drone hasn't been flown  for more than one  month. Third, a compass interference warning appears in the DJI Go 4  application, and the warning persist after changing location."
With that said, you can calibrate drone's compass (or compasses) till cows come home and it won't hurt anything or improve over 1st compass calibration - so long as you do compass calibration correctly.   DJI's manual says "Only calibrate compass when"; but as noted above there are execptions.
One critical aspect of proper compass calibration is making sure drone is well away from (I believe DJI has recommended > 10-meters) and not being effected by stray sources of magnetic fields.  Make sure when calibrating drone's compass you have nothing on you which could produce magnetic field interference, cellphone in hand, ferrous metal ring or watch, etc.  Only magnetic field source you want, is the Earth's.
2022-5-4
hallmark007
Vtcats Posted at 5-4 11:34
Compass warnings and old myths are just something of the past. I have flown 14 dji craft and I think I calibrated 3/4 times, but never once in the last 3 years and I have flown a lot in many different countries and different locations. And while you’re free to calibrate at anytime it will never improve a good compass.
2022-5-4
Labroides
Flight distance : 9991457 ft
HedgeTrimmer Posted at 5-4 12:06
Even in those situations, there will almost never be a need to recalibrate anything.
When you think the drone is asking for compass calibration, it's >99% of the time warning of a problem in the area and you should just move away from the problem.
In your second example, it's the same thing ... just move away from what caused the drflection of teh compass and start again.
2022-5-4
Bussty
Flight distance : 320951 ft
New Zealand
Labroides Posted at 5-4 16:41
Was it you that said except for the Mini 1?  That drone asks for calibration almost every single time
2022-5-4
Labroides
Bussty Posted at 5-4 19:09
Not me ... I've never suggested that
2022-5-4
HedgeTrimmer
I would agree.  Usually it takes only moving to another location.   Not always.
In moving to new location; I would take step of powering drone off before moving**.  Then, moving near new takeoff point.
While holding drone in air, powering drone up like you would for hand-launch.   Then placing drone on ground at new takeoff point.
Finally check for any magnetic field interference.
** I have seen problems with drone detecting magnetic field interference when it is powered up in field of interference and moved to new location.  Drone seems to be de-sensitized to deviations or drone continues to hold corrections which no longer apply.
2022-5-4
HedgeTrimmer
You may have a drone with defective compass system.  I used to own a Mavic Pro which would almost always on first flight of day call for compass calibration.
I could move drone 10-feet to 100-feet several times, and drone still would insist compass needed calibration.   Only way to stop getting messages for that day was to do a compass calibration.
Drone insisting on re-re-re-re-re-compass calibrations got so bad, I started ignoring the messages.  Drone was finally repaired or replaced, and that was end of calls for compass re-calibrations.
You may also be:
1) flying from area(s) with magnetic field interferences
2) not doing compass calibration correctly
2022-5-4
Labroides
HedgeTrimmer Posted at 5-4 19:43
That makes no sense.
It's not consistent with the way the compass sensor works and what calibration actually does.
2022-5-4
HedgeTrimmer
Labroides Posted at 5-4 20:21
Then what did you mean by following?
"Even in those situations, there will almost never be a need to recalibrate anything.
When you think the drone is asking for compass calibration, it's >99% of the time warning of a problem in the area and you should just move away from the problem."
2022-5-4
hallmark007
There was a drone the air1 that continually asked for calibration. But that was a problem with the drone almost all users did not have this problem.
There have over the years been conflicting notes in different manuals that made no sense and certainly no explanations came with the ridiculous information . So many myths appeared and it seems they are still here today. But the very best advice is there is no need to calibrate your compass unless prompted to or move to another location and carefully watching the small triangle and its heading will insure your compass is on the right heading.
2022-5-4
Labroides
HedgeTrimmer Posted at 5-4 21:00
I meant that the only time you should need to recalibrate the compass is if you modify or rebuild the drone.
If you get a message that you think is suggesting you recalibrate, it probably isn't.
Power off, move the drone and try starting again somewhere else.
Recalibrating the compass isn't needed when the problem is the launch spot, not the drone.
2022-5-4
Bussty
New Zealand
hallmark007 Posted at 5-4 23:06
Yeah the Mini 1 asks a lot. No difference hand launching or on a flat non-metal surface, especially if you change location. Has done it from day one. Not a biggie there is usually no one around when I do the dance :-)
2022-5-5
Labroides
Bussty Posted at 5-5 03:31
There is nothing at all about changing location that has any effect on the compass.
What happens if you just ignore the message and fly?
2022-5-5
HedgeTrimmer
Labroides Posted at 5-4 23:26
Totally agree.
(I misunderstood your previous reply.)
2022-5-5
Bussty
New Zealand
Labroides Posted at 5-5 04:57
Didn't know you could!  I'll try....
2022-5-6
Bussty
New Zealand
Typical! Launched it several times today and no sign of Compass Calibration Warning. I guarantee if  I drive 20mins down the road and try it will prompt. Will try again....
2022-5-6
Labroides
Bussty Posted at 5-6 22:26
If it does, it's a false alarm.
There is nothing at all about driving 20 minutes away or 2000 miles away that will have any effect on your compass calibration.
2022-5-6
