Drone DJ has new info on GPS issue
1515 13 2022-4-8
Mavic 3 Raptor
Flight distance : 3014675 ft
https://dronedj.com/2022/04/06/dji-acknowledges-continued-mavic-3-gps-issues-states-fix-to-come-within-the-next-two-months/
Just passing along what I read.
2022-4-8
StanMaster
Banned
2022-4-8
_StanMaster
I wish to apologise for being a douche.
2022-4-8
_DAFlys
Banned
2022-4-8
TonyPHX
Flight distance : 11229610 ft
Well this is good news and does take away the commentary that DJI is not acknowledging or working on this issue.
2022-4-8
HedgeTrimmer
From linked article: "‘within the next two months’ "
Way to long for a problem which has already been around to long.
2022-4-8
GaryDoug
Flight distance : 1264639 ft
The longer a certain event carries on in the eastern European area, the longer the fix will take. I believe they are very much connected. It seems to be no accident that I am missing about half of a certain type of satellite on a scan app on my phone and you know which ones they are. Months ago they were about equal in number. The number of remaining usable ones seem to match the count on my M3, about 12. No matter how long I wait, I never see more than 13, and 12 looks to be the approximate operational threshold. Why only the M3? I have no idea...yet.
I think the "new info" is just a smoke screen to delay expectations.
I served in the US military in the old days when we used LORAN for large area navigation. Every LORAN timer/transmitter we used had an accessory slot that could be populated with a code module that would render reception of the signals useless or very inaccurate unless the receiver had an identical module installed.
2022-4-8
TopDrones
Flight distance : 326191 ft
_StanMaster Posted at 4-8 11:04
2022-4-8
HerrMittmann
Flight distance : 2362441 ft
This feels very similar to the situation in the gaming industry, for example when you look at Halo Infinite...
2022-4-9
djiuser_CgYhBqmxP83j
Flight distance : 1078150 ft
GaryDoug Posted at 4-8 17:41
The GPS chip can use the four major systems but can only use three at a time. Before the war they swapped from the aging Russian system to China’s for one of the three. If anything the swap has helped Ukrainians because Russia would have likely done what the USA does with GPS civilian band which is decreased accuracy in the area of the war zone.
2022-4-9
GaryDoug
djiuser_CgYhBqmxP83j Posted at 4-9 01:50
That is all public information I suppose. Do you not think there is something going on that is not common knowledge? War is not predictable when done right.
2022-4-9
Mattft86
Flight distance : 73081 ft
I too have received this from dji today after sending them another log from my m3.
Amara (DJI Support)
2022年4月10日 GMT+8 23:24
Dear Matt,
Thank you for your patience. We apologise for the delay in getting back to you.
In regards to your issue, we have received an update from the relevant team.
For your information, the latest firmware 0600 optimizes most satellite search and signal interference problems to improve the user experience. However, we are aware of user's concern regarding DJI Mavic 3’s slow satellite search upon powering on and we have already located the problem. We have noticed that it takes additional time for some Mavic 3's users to connect to satellites in some high-latitude areas. We have located the cause of this issue and will address it directly in a firmware update within the next two months.
It is worth noting that satellite acquisition time, also known as time to first fix (TTFF) is also affected by internet connection. If the aircraft is not connected to the internet, a cold start of its GPS receiver will result in a TTFF of approximately one to two minutes under ideal satellite signal conditions. A cold start can be avoided if the previous flight was within 40 minutes. In general, TTFF is significantly reduced when the aircraft is connected to the internet. User satisfaction is always at the heart of our work. We will continue to improve your experience.
Hope this email clarifies your confusion.
Thank you for choosing DJI.
2022-4-10
Dronezee
Banned
2022-4-10
Mattft86
Dronezee Posted at 4-10 17:20
The “high latitude” statement is total BS. If it was a thing, the users of all DJI drones would also have the same problem at high latitudes (and they don't).
It's spin that ignores all the users having the GPS problem in non-high latitudes and is a weak attempt to placate the gullible.
Yeah i know i think they have been given a script to read..
2022-4-11
