Fly App & continuous photo numbering problems...a question
572 5 2022-4-21
Sean-bumble-bee
Flight distance : 15997 ft
If, for you, the numbering is NOT continuous across card changes or emptyings etc.  in what circumstances did/does that happen i.e. precisely what did/do you do with the card/s e.g. did/do you format the card/s, if so where or how? Do you use a reader or.......... etc. etc. etc.?
What drone?
I have never experienced a problem and swap cards quite frequently, any formatting of the cards is done in Windows but as a rule I do not format a card when I empty it. For downloading or emptying my cards are removed from the drone and placed in a reader attached to the computer.
I suspect there is a pattern to be discovered.
2022-4-21
Labroides
Flight distance : 9991457 ft
The pattern was discovered long ago.
There's nothing complicated about it.
If you use the Fly ap and give the camera a clean formatted card, it will always start at 001.
If the card has image files, the camera will continue the numbering from the latest file.
2022-4-21
Sean-bumble-bee
Labroides Posted at 4-21 02:53
Yet none of my fly app using drones (I have more than 5 of them) do that (start from 1), and that includes the use of freshly formatted via windows cards. I run H2testw on every new card  and then format the card to remove the test files so, a new card of mine is always freshly formatted.
How does that fit with your pronouncement?
2022-4-21
Labroides
Sean-bumble-bee Posted at 4-21 03:31
Then yours performs differently from all the others out there.
Like the one in this thread: https://forum.dji.com/forum.php? ... D556%26typeid%3D556
2022-4-21
blue_canyon21
Flight distance : 23370489 ft
That's not the case.
My Mini 2 is on it's 3rd freshly formatted card. Each new card continues the numbering from the previous card.
After reading this post, I formatted the card in my Air 2. After inserting it into the drone and taking a photo, it doesn't reset to 1. However, changing the storage location to local storage did reset it to 1. But upon formatting the local storage, it didn't reset.
2022-4-24
Labroides
blue_canyon21 Posted at 4-24 06:08
Since the Fly app was released users have complained that there was no continuous file index available.
But in the last week, there was another thread on this and a member pointed out that it works if the SD card is formatted in the computer.
2022-4-24
