set Video Resolution for MA2
1172 3 2022-5-19
Ivan Lopez
Flight distance : 52982 ft
Mexico
Hi,
I'm trying to set the video resolution with ResolutionAndFrameRate but I get the "Not supported by current firmware.(255)" error.  I read in the forum that with Mavic Air 2 and DJI Air 2S when setting the camera mode you have to use setFlatMode instead of setMode, so I was wondering if ther is another function to change the video resolution for MA2 and Air 2S?
Thanks
2022-5-19
Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
Share your code, platform and SDK-version. Have you looked at the gihub example? Is it the recorded resolution or the livestream you want to change? What resolution are you trying? Are you using keys or methods?
2022-5-20
Ivan Lopez
Mexico
Hi,
Thanks for your reply.  I'm using Android MSDK 4.16.  Testing on:
- Mavic Air 2 firmware 01.01.0720
- Remote Controller firmware 04.11.0032
Code:
SettingsDefinitions.VideoResolution resolution = SettingsDefinitions.VideoResolution.RESOLUTION_1920x1080;
SettingsDefinitions.VideoFrameRate frameRate = SettingsDefinitions.VideoFrameRate.FRAME_RATE_24_FPS;
ResolutionAndFrameRate resolutionAndFrameRate = new ResolutionAndFrameRate(resolution, frameRate);
DJISDKManager.getInstance().getProduct().getCamera().setVideoResolutionAndFrameRate(resolutionAndFrameRate , new CommonCallbacks.CompletionCallback() {
    @Override
    public void onResult(DJIError djiError) {
        if (null == djiError) {
        } else {
            String errDescription = djiError.toString();
Thank you.
2022-5-20
Ivan Lopez
Mexico
Mats Bohlinsson Posted at 5-20 00:57
Hi Mats,
I shared my code, platform and SDK-version.  And is the recorded resolution I'm trying to chenge.  I uploaded my code also.
Thanks
2022-7-12
