JJB*
Flight distance : 12373104 ft
Hi,
If you are interested in analyzing flightlog and has read this post with some interest > https://forum.dji.com/forum.php?mod=viewthread&tid=265331
The flightmode shown in the FlyApp isn`t always correct. When flying in ATTI mode or when the stabilisation is done by the Vision system the flightmode doesn`t change on the screen. ATTI warning is shortly seen + audio (but not always...)
The top right GPS icon in the FlyApp shows the number of receiving satellites and the colour (red,amber,white) gives us information about the GPS 'health'.
Or as i name in the "quality" of the receiving sats ; 10 sats in a row in the sky is not that good, 8 receiving sats spread out in the sky gives a more accurate GPS LatLon position.
Red = not enough 'health/quality' to have good LatLon data ; do not fly.
Amber = enough 'health/quality' to have good LatLon data, thus drone can fly in GPS stabilized mode (n mode, c mode, sport).
White = enough 'health/quality' to have good LatLon data to set HomePoint.
In the CSV this 'health/quality' is read in the column "OSD.gpsLevel", value range 0 - 5.
2 more columns are nice to understand, "OSD.isGPSUsed" and "OSD.isVisionUsed".
OSD.isGPSUsed = True is almost always TRUE, it get FALSE when GPS data is simply not received OR is FALSE when drone decide not to use GPS receiving data *.
( * with large yaw/compass errors turns into FALSE but LatLon data is still received and written into the flightlog)
"OSD.isVisionUsed" turns into TRUE the moment GPS data isn`t there to stabilize drone, if within sensor range + enough reference + enough light Vision is used to stabilize the drone.
This mode was called OPTI mode, this naming is kind of dissapeard....
With 2/5 or 3/5 (amber GPS icon) a FlyApp drone is flown in a GPS mode.
PROBLEM is that the FlyApp does not show ATTI or OPTI mode as a flightmode, same for the mode naming in the CSV file....so without some knowledge sometimes logs are wrongly analyzed.
See the video : started my MA2 flight with 0 satellites ; see what is shown on the screen.
In the picture : P-GPS is there with 0 satellites! See that 2/5 gives a "Gentle GPS" (csv naming) Flightmode, my N mode [bypass] = naming Fly App.
BTW picture shows data as from PhantomHelp CSV (online conversion) and my own analysis program.
HP is set the moment icon turns white = 4/5 or 5/5 for 'health/quality'.
If you have doubts about if drone is flying in GPS mode or in ATTI mode, look for evidence in the log as follows: (see chart)
Find records where the RC forward input is zero to fwd input to zero. In next text assume no wind. (head, cross or tail wind had influence on drone attitude)
GPS mode :
zero to fwd input > drone pitches down > speed increase | fwd input to zero > drone pitches up * > speed to zero > drone flat pitch = stable in hover
* braking
ATTI mode :
zero to fwd input > drone pitches down > speed increase | fwd input to zero > drone to flat pitch **> speed not always to zero *** (if wind then drifing on the wind).
** not braking, *** counter input is nesseccary to stop forward motion.
Any questions ; just ask.
Cheers
JJB
