Adjusting braking sensitivity
3570 27 2022-6-6
MHM
Does anyone know how I can adjust the braking sensativity on the  macic 3.  The M3 braks very hard upon stoping left/Right Forward/Backwards. Has anyone else  noticed this on the M3 ?
2022-6-6
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and sorry for your inconvenience. You may adjust the EXP value upon your usage and habit. EXP refers to the drone’s exponential. Adjust the parameter to obtain the ratio between the different physical stick movements and the output stick movement. When moving the control stick in the same manner, the higher EXP, the faster the aircraft speed. If you are a newbie, we do not recommend modifying EXP on your own. Please use the default value. Currently, you can adjust the remote controller EXP under “Advanced” in the “Control” settings when using DJI Fly. Hope this helps. Thank you for your support!
2022-6-6
CloudVisual
Flight distance : 97545420 ft
DJI Paladin Posted at 6-6 19:14
Braking and Exp aren't the same thing...
2022-6-7
MHM
I agree braking and exp are not the same thing.  Has anyone experienced there M3 brakes hard upon stopping left/right forward/backwards.  Is this normal our do I need to return the M3  to Best Buy for a new M3
2022-6-7
Mzp
MHM Posted at 6-7 18:03
You can also try in Safety menu change the Obstacle Avoidance settings. It is normal for Mavic 3 to be a bit jerky. You can set the settings as follows:
Obstacle Avoidance:
Brake (smoothest, but drone will stop when hits obstacle) or Bypass (will navigate around obstacle)
If you choose Bypass, you can chose Nifty mode underneath it, to smoothen out the braking. Hope this helps.
Thanks, Mike.
2022-6-7
Labroides
Flight distance : 9991457 ft
Mzp Posted at 6-7 18:16
Obstacle Avoidance:
Braking when you go hands-off ... not obstacle avoidance.
2022-6-7
CloudVisual
Obstacle Avoidance:
This isn't OA braking, it's like someone's turned the brake setting to 400%. I never fly with OA and it's just ridiculously sharp at stopping at even the slowest speeds.
2022-6-8
Mzp
CloudVisual Posted at 6-8 02:01
ah wow this is interesting, not sure if I noticed this one.
2022-6-8
Mzp
Labroides Posted at 6-7 22:09
yes I hear you, I just saw a video showing Mavic 3 being jumpy and breaking hard when OA was on
2022-6-8
PortlandProDrones
Flight distance : 1231155 ft
I’m having the same issue. I’m coming to the Mavic 3 from an Inspire 2 and the Go 4 app. Here’s what made sense to me. I could adjust braking sensitivity in the Go 4 app.
Unfortunately exp setting will not correct the hard stops. DJI fly app is missing sensitivity setting for braking.  I’ve just learned to except it until DJI decides to add to the fly app.
2022-6-20
CloudVisual
Posting this here to show the issue compared to the Air 2s.
2022-6-21
Mzp
+ 1 also noticing this now.
DJI , could you please add breaking sensitivity setting to DJI Fly App similar to DJI Go 4 , i.e. for Mavic 3 and other drones.
Thanks in advance, Mike.
2022-6-21
hallmark007
Flight distance : 9827923 ft
Obstacle Avoidance:
You are correct, changing OA to bypass or turning off will stop the drone breaking as hard as when its permanently in Break mode.
2022-6-23
MHM
Hopefully DJI will take care of this with a future firmware update or add sensitivity adjustment. I found a video on YouTube from DRONE VALLEY……. Search “DJI Mavic 3 drone-first flight”. His video shows the Mavic 3 coming to a smooth stop from left to right forward and backwards.  Check out link below.
https://YouTube.be/uQPx7Qk-TEs
2022-6-23
Monkey007
Flight distance : 73775046 ft
Not sure if some of us are getting confused with 1) the jerkiness in braking, 2)smoothness of the actual footage, and 3)the ability of the drone to fly very slowly.
Personally I'm finding:
1)the jerkiness is surely a lot more obvious than other DJI drones I've used, and it looks very unprofessional and scary to onlookers, especially if you're a professional doing a job.
2)the camera gimbal seems to be doing a great job absorbing this jerkiness, as I haven't seen the jerkiness on my videos so far. So the allegation of shots getting ruined by this jerkiness is not quite valid, at least not from my own experience.
3)not being able to fly slow enough may ruin the shots when you're flying close to obstacles and filming close subjects, but I can't see this to have anything to do with the braking sensitivity.
2022-6-23
hallmark007
MHM Posted at 6-23 13:11
I have found that without OA or in Bypass mode close flying is much smoother in Cine and normal mode that with OA on and flying in break (brake) mode. There were problems with bypass mode pre update but it has improved hugely since then.
2022-6-23
Mzp
hallmark007 Posted at 6-23 08:59
Yes it seems OA turned on does have affect on hard breaking, need to do more testing on it...
2022-6-23
Labroides
Mzp Posted at 6-23 17:00
The Mavic 3 still brakes savagely when OA is disabled.
And if you are reading this Hallmark, note the spelling of the word brakes.
When your drone brakes, it comes to a stop in the air.
When your drone breaks, you've wrecked it.
2022-6-23
Monkey007
Labroides Posted at 6-23 18:04
Have always wondered if it was just an auto-correct thing, and surely he's not the only one.
2022-6-23
hallmark007
Right got it, this is actually the correct spelling for me, “ coscán“ but if I wrote in Gaelic nobody would understand. Check post 11 or are you slipping up..
2022-6-24
hallmark007
Monkey007 Posted at 6-23 20:59
English is not my first language, Gaelic is, hopefully I spell better in my native language.
2022-6-24
Labroides
hallmark007 Posted at 6-24 00:08
No ... I'm not slipping up.
I got sick of seeing egregious spelling abuse and yours was the last straw
2022-6-24
hallmark007
Labroides Posted at 6-24 02:11
Life’s obviously a stretch for you..,
2022-6-24
Mzp
Yes agreed Labroides. It still does stop rather abruptly even if OA is turned off completely, maybe a bit better than when OA is turned on. I think that's why they added the Nifty mode for OA bypass type as people were complaining about jerkiness with OA. Hopefully DJI could add Tripod like mode and introduce brake sensitivity setting similar to DJI GO 4 in a future firmware update. Would be really nice if they could. I am actually guilty of misspelling brake as break, my bad. I think I misspelled it and auto correct gave me a wrong brake, thank you for pointing this out, these words do sound alike , but have different meanings, would rather have M3 do proper braking, than breaking on me when it comes to flying my drone
2022-6-24
Grimtheviking
Flight distance : 11796312 ft
Dji Please update the Fly app with the braking sensitivity settings as in the Go 4 app. Braking on the M3 is too harsh, it needs smoothing out. Thank You.
2022-6-25
hallmark007
CloudVisual Posted at 6-21 01:33
https://youtu.be/jiLz2zsiKis
The Air2 or Air2s doesn’t have brake sensitivity, everyone keeps on about brake sensitivity, I own two phantoms and brake sensitivity isn’t as good as what the Air2s has .
2022-6-27
CloudVisual
hallmark007 Posted at 6-27 09:35
Except that all drones with a GPS mode have a brake sensitivity setting, it's what tells the drone how hards to come (brake) to a stop...
Your Phantom 4 also has it and there's a way to adjust how hard it comes to a stop (braking) it in the settings.
2022-6-30
hallmark007
CloudVisual Posted at 6-30 04:46
Yes you’re right I can adjust Phantom, but no matter how hard I try to adjust it it will never look as good as my Air2s, but as far as videoing “its no difference” to me at this stage this is more to do with cosmetics because I haven’t seen the really bad recordings due to this. I’d much prefer to have extra control of speed in Cine mode..
2022-6-30
