Cine or Normal Obstacle avoidance is auto turn off
3033 15 2022-6-6
David-Air
Flight distance : 4717963 ft
Hi all
I was flying yesterday evening a well lighted path trying active track.  The controller is set to Cine or Normal with obstacle avoidance pass by turn on.  However, the controller obstacle avoidance icon is showing RED.  I tried a number of time and is still RED.
Does anyone know why??
Thanks in advance
DW
2022-6-6
Bashy
Flight distance : 2354357 ft
Yeah, the well-lighted path is a giveaway, it's not well lighted enough probably, night time is not your friend, low light is not good for OA no matter how lighted you think it is, it probably isn't, try the same place during the daytime and see if it works then.
2022-6-6
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to fly the unit in the daytime to see if you still experience the issue? Always fly in open areas and keep your drone within line of sight. For safety reasons, you should never fly above people, animals, or moving vehicles. Here are the tips for flying the drone: https://www.dji.com/au/flysafe?site=brandsite&from=footer.  Thanks and fly with caution.
2022-6-6
Nuh7
Flight distance : 256411 ft
Turkey
I assume you have the camera at 4k. Have you set it to 30 or 60fps?
2022-6-7
djiuser_ZiE029dmv9SE
Flight distance : 890338 ft
Same trouble I have been having ?
2022-6-23
and yes it was middle of the day, with no over hanging trees, full daylight and before I knew it, the obstacle avoidance had switched to red, and was unable to get it to turn back on ? I had to turn off the drone and restart it, but to have it turn off without me knowing is so dangerous
2022-6-23
THE PRISONER
no answers yet, very strange ? .......... we must have a defective unit if its only us having this issue !!!
2022-6-30
djiuser_gwqTdBwTT9WF
Flight distance : 198104 ft
Hey, i have the same problem with a brand new Mini 3 Pro / DJI RC. I updated everything with the latest Firmware with no issues. The status symbol for the sensors stay red all the time when i touch the symbol, it shows a message that says "Sensor Normal"... i tried any resolution and fly mode cine/normal flying in normal daylight and lowlight with no difference. Do yu have any solution for that?
2022-11-11
David-Air
djiuser_gwqTdBwTT9WF Posted at 11-11 15:44
Are you in sport mode?  If yes, in sport mode all OA will turned off permanently.  OA works only in Cine and Normal.  Hope that helps.
2022-11-11
t3ak
David-Air Posted at 11-11 16:33
Hey, thanks for your response. No, i'm not in Sports Mode...  could you solve your problem?
2022-11-11
Bashy
Is it turned on in the settings?
2022-11-11
David-Air
t3ak Posted at 11-11 16:44
Are you fly in a relatively low light
2022-11-11
t3ak
Bashy Posted at 11-11 19:14
Yes, i switched between Bypass, Brake, Off. But i guess the light situation was really the problem... so it is highly recommended to have good light for these sensors. I will do a couple more tests. Thanks for you hint.
2022-11-12
t3ak
David-Air Posted at 11-11 20:52
I think that might be the problem. I was flying in my backyard this morning and the OAS worked great. I tried bypass and the drone flew over my shed with no problems. The brake function also worked great so it didn't fly into any obstacles. I cleaned the sensors before the flight.... they didn't look dirty at all, but I read that the sensors are very sensitive. Another thing was... the app staret the tutorial again.... That when you first start the drone. So yes, they seem to work fine and the light conditions seem to have been the problem. But I will test them out a little more later outside.
2022-11-12
cwkiiffner
djiuser_gwqTdBwTT9WF Posted at 2022-11-11 15:44
I asked this question in (apparently) the incorrect thread, so I'll repost it here - does the obstacle avoidance turn off (stay red) when flying in a no-fly area (Geozone)?  Could be that be the problem we're experiencing?  My sensor is red all the time and the DJI map shows I'm in a "warning" zone.
2023-3-21
Zoooom
Put it in 1080p 30fps H264 and see if it changes. Then turn on and off, I think.
2023-3-21
