JJB*
Flight distance : 12260774 ft
DJI Stephen Posted at 6-6 19:43
Hello there Bigplumbs. Thank you for reaching out and I am sorry for the trouble this has caused. Just a friendly reminder that when flying above the water, the vision positioning function will turn off automatically and only the GPS and barometer are used for positioning, if affected by the accuracy range, and an accident might happen. Thank you and fly safe always.
Hi Stephen,
I have to ask again....
What do you mean with "affected by the accurancy range" ??
If only GPS (horizontal positioning) and Barometer (vertical positioning) are used, as you are saying, both are not out of range when flying at low height!
And ofcourse GPS and Barometer has no clue whatsoever if the drone is flying low above water or any other surface.
So why is it possible than that a accident might happen?
Or does the lower vision sensor (still active flying over any surface) measures 'faulty' heights and is that signal confusing the barometer height wich result lowering the actual fly height?
cheers
JJB
