HamDesigner
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 33996 ft
nosnoop Posted at 6-15 14:10
Even though it is generally good advice for Lipo battery care, but the link above mainly refers to non-smart Lipo batteries used in RC community, and most are not relevant to the smart DJI batteries for Mini 3 Pro. Basically, the DJI batteries (like your smart phone batteries) are quite fool proof, you can do your normal charging, use it, store it, and the battery would do the rest. As long as you don't go to extreme like keeping 100% all the time, or 0% for long period, you would be fine.
I think that link was in response to the query of at what voltage does one typically store the battery - just for those of us who would want to know the actual voltage levels. Inside that case is the exact same cell design as used in the RC community, with the addition of some idiot-proof tech.
Indeed, for those of us used to flying RC aircraft which require constant stick inputs and huge amounts of hours of gained thumb skill, it's nice to not have to wipe down the side of the aircraft due to the oil residue from the glow fuel or be diligent about properly storage charging/discharging and balance charging several batteries that evening after a weekend at the field, these smart batteries take all of the work out of owning them. It's also nice to be able to remove one's hands from the controller to scratch one's balls without watching the aircraft pirouette into the closest hard surface. In comparison, flying a modern sUAS is like pressing the easy button, except you don't even have to learn how to press it. |
