Hi I don't have a 2sec interval on my mini 3 in hyperlapse it starts with 3seconds,any one else tried to hyperlapse and find out if the 2sec is available
For optimal performance, use Hyperlapse at an altitude higher than 50 m and set a difference of at least two seconds between the interval time and shutter.
I presume that is why the minimum is 3 seconds.
I presume you are referring to Aldryn’s YouTube video, he must have been using pre-release software.
onymar Posted at 6-17 08:51
Found the following in the PDF:-
So it's a software issue. I tried it put up at 120 m .shutter was 1,200 and in 1080p still only 3 seconds interval available.
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to uninstall and reinstall the DJI Fly app on your mobile device to see if the issue persists? In addition, kindly please send us a screenshot showing the option that you have when doing hyperlapse. Please keep us posted. Thank you.
DJI Paladin Posted at 6-18 01:39
I uninstall and reinstalled the dji fly app and firmware update but still don't have the 2 second interval in hyperlapse still starts at 3 seconds. I think others have have the same issue.
Hi appreciate your help but tried everything still started at 3 seconds interval. There was a you tube video posted doing a hyperlapse tutorial on way point's he was surprised that the 2 seconds interval was not available.
I always use 2s interval for hyperlapse, however recently the minimum became 3s, I tried rebooting RC and mini3pro but no help, also tried to fly to 60m height and still shows 3s.
Hi there, may I know the current firmware version of your DJI Mini 3 Pro? Please try to update to the latest version for a test.
Fully Posted at 1-19 21:04
I have tried calling DJI support about this. I cant get 2 second intervals anymore. I defintely did hyperlapses with 2 seconds on 29/12/22 .
Has anyone actually solved this or found out what is stopping it going from 3 sec minimum to 2 second????
Hi there, sorry for the late reply. May I ask if the issue is resolved? If not, please let us know.
