selecting where to store media
2363 3 2022-7-1
tommix
I have a DJI Air 2S and am using a smart controller, I have installed SD cards in both the drone and the smart controller.  When taking photos or videos I would like the images saved on the sd card in the smart controller.  Is there a way I can default the images to be saved there?  Do I need to remove the SD card from the drone?
Thank-you
2022-7-1
Fred Fred Fred
Flight distance : 4512966 ft
Hi Tommix, on your flight screen when connected to the drone at the bottom right corner it will show how much storage is available in the drone and if you click that you can change between your ssd or onboard storage if that helps or you could find it under the settings on the top right corner of your flight screen and under I think either control or camera you can select their to.
2022-7-1
DJI Stephen
Hello there tommix. Good day and thank you for reaching out. It is best to put a microSD card on your DJI Air 2S. The microSD card on the DJI Air 2S will record / store all photos and videos captured and filmed in high quality. The microSD card on the DJI Smart Controller is only for recording low quality, and preview copies of the photos and videos captured. Thank you.
2022-7-1
tommix
Thank you both for the replies, I am a new drone owner and have a LOT to learn.  Thanks again.
2022-7-2
