DJI Natalia
KlooGee Posted at 7-3 07:47
I can confirm that the map and buttons on the right side don't work at all on the DJI RC after the latest update that includes DJI Fly v1.6.8.
The maps work fine with the RC-N1 with my iPhone and Android based TriplTek tablet. However, the map does not work at all on the DJI RC. I don't personally have a RC Pro, but I've seen reports of similar behavior of the maps not working on it as well after updating to v1.6.8.
Hi, there. Sorry for the inconvenience caused. We will check these problems and keep you updated. And also, for the problem of the map: we recommend that you connect the DJI RC to the drone in an outdoor open environment, then connect to the Internet and check whether the map can be loaded normally. If there is any problem, please send us the log of the DJI RC via Google drive or Dropbox. Please don't worry. We will do our best to help.
Export log from DJI RC: After connecting DJI RC to DJI Assistant 2, click "Export Log", select the log to be exported, and click "Save Local". |
