Master Shots Settings
3269 5 2022-7-3
Greg_Toronto
Mavic Air 2S
Is there a way to set limits on the gimble during a Master Shots recording?
I would like to avoid the gimble panning to the point that it has the propellors in the frame as seen in my video.
Cheers,
Greg
2022-7-3
FlanniganFlyer
Flight distance : 1240148 ft
https://youtu.be/LTALpwfiedU  try this tutorial, if I'm right there is a setting in the menu to prevent prop shots while using master shots, good luck.
2022-7-3
DowntownRDB
Flight distance : ****
I fixed that issue by going into the settings of Fly app, Camera Tab and changing Shooting Mode to Composition.  This keeps the props from showing in your video but be advised that it does turn off Obstacle Avoidance.
Hope this helps.
2022-7-4
Greg_Toronto
FlanniganFlyer Posted at 7-3 15:43
Thank you for the help
2022-7-4
Greg_Toronto
DowntownRDB Posted at 7-4 05:51
Hope this helps.
Oh! No obstacle avoidance. That can't be good if you are in a busy area, especially when Master Shots is an automatic feature.
Thanks for the help and the heads up.
2022-7-4
DowntownRDB
Greg_Toronto Posted at 7-4 07:31
You're very welcome.
Hope you have a great week.
2022-7-5
