How often replace blades ?
1193 11 2022-7-11
FlipperDrone
Flight distance : 4224925 ft
I've had a Mavic Pro for 5yrs and never changed a blade on it due to wear and tear. Same with Phantom before that. With the Mini3 Pro I got spare blades with the unit and then more with the Fly more pack......do the blades on the smaller drones really wear out that quickly or are they intended purely for damage repair on crashing etc ?
2022-7-11
TomMG
Usually you don't have to replace them unless they are damaged or bent.
2022-7-11
Mavic57pro2
Flight distance : 3772247 ft
Never changed blades on Mavic Pro, M2P, Mini 2 and probably won't on the Mavic Mini 3 Pro either unless I damage them.
There is no maintenance schedule advising changing blades that I know of.
2022-7-11
Blériot53
Flight distance : 6188465 ft
Ove 5 years I've had a Phantom 4, a Mavic Pro Platinum, a Mini One and a Mavic2 Zoom. Never had to change a blade except a chipped one from trimming a hedge.  So I would say, that's the purpose they' intended for.  Regular safety checks are routine of course.
2022-7-11
Sean-bumble-bee
Flight distance : 15997 ft
Ditto all the above but would add, occasionally check the screws are nipped up. Bearing in mind their size don't give them a great deal of torque if you strip the female thread you would be in diffs.
2022-7-11
FlipperDrone
Thanks for comments all !
2022-7-11
The Saint
Flight distance : 5902228 ft
it's a hold-over from the old days when it was more necessary.  today, it's a ploy to make you think you are getting something even if you can't use them.  as of now, extra unwanted blades are just trash polluting the environment.
2022-7-11
Blériot53
FlipperDrone Posted at 7-11 10:34
2022-7-11
Bigplumbs
Flight distance : 620164 ft
The Saint Posted at 7-11 10:39
Bang that Drum boy.............. Its all a conspiracy..... Why dont you glue yourself to DJI HQ that will help a lot.
If you want any cred with the whole Eco thing you will have to move
2022-7-11
The Saint
Bigplumbs Posted at 7-11 12:45
there are more people in my country who care about the world than your entire population
2022-7-11
KLRSKIR
Flight distance : 28368625 ft
200 hours and mine are in the garbage.
2022-7-11
DJI Stephen
Hello there FlipperDrone. Good day and thank you for reaching out. Just a reminder that before each flight, it is necessary to check your DJI Drone's propellers for cracks, wear, warp, corrosion, and damages. If any of these conditions are present, the DJI propellers should be replaced at once. Damaged propellers can lead to unwanted incident when flying your DJI Drone. Thank you and fly safe always.
2022-7-11
