DJI Susan
Greg Inspire 2 Posted at 8-30 05:30
This problem has been there right from the start when I first switched on the drone
I then did all the firmware updates but still having the same problem
The zoom camera not working, just showing a white screen
Hi there, please try to refresh the latest firmware for the drone, and relink the aircraft and controller. Try to select cameras between Zoom and Wide/Thermal camera multiple times. If the issue persists, we may suggest that you send the drone in for a further diagnosis.
May I know where are you located? If you are located in South Africa, kindly contact the reseller for assistance. Or you can contact our support via email at http://www.dji.com/support for further guidance. |
