frankymusik
Flight distance : 27904331 ft
BladeZ Posted at 8-21 14:45
Thanks for the reply. I just took another flight with it and never received the warning. Had a pretty good distance away (With still being VLS). Something else I've noticed is the mini-map is just blank. The drone doesn't show, the map doesn't show. Just a blank screen. Is there something I'm supposed to do to get the map on there? [view_image]
... use a hotspot (e.g. the smartphone) or download the map at home (via wifi) before the flight...
If you use the hotspot, then you have to go to the map display before the drone has started flying, otherwise the WLAN connection is switched off automatically... |
