Mavic 3 obstacle avoidance sensors off
3882 7 2022-8-30
fly.overflying
Today 8/30 I got a Mavic 3 I bought from DJI in exchange of the Mini 3 Pro after numerous unresolved issues. After I did all the required updates I finally got ready for the first fly and for my surprise the obstacle avoid sensor signal was red during the entire time, I was flying and record 4K 60 in Cine and normal mode, settings for the senso was "bypass". I also noticed one sudden break during the fly.
Before anything can someone confirm if this still an issue since I read outadated treads from beggining of this year. I also noticed the same issue with users flyghting the Mini 3 Pro.
Any thoughts and updates will be appreciated.
Thank you
2022-8-30
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to download the DJI Assistant 2 software and perform the vision sensor calibration and check if the issue persists? You may also calibrate the IMU of the aircraft before having the test flight to see if there are any changes. You may download the said software using the link below. Please keep us posted. Thank you for your valued support.
https://www.dji.com/downloads/so ... sumer-drones-series
2022-8-30
Tornado12
Flight distance : 356391 ft
Were there any errors on screen? Typically if sensors are turned off for some reason, such as low light, you get a notification in the app about it. When and where were you flying? If you were flying late in the day when light is low, the sensors will turn off. For sensors to work they need to be enabled in the settings, you need to be in flight, and it needs to be daylight outside. Did you do a little test to see if the sensors were working? Fly slowly toward a wall and see if the drone tries to avoid it in bypass, or stops completely in brake mode. If the drone flies right up to the wall then sensors are off, obviously. Toggle brake and bypass and test both.
2022-8-31
OlliM1971
Flight distance : 309199 ft
DJI Paladin Posted at 8-30 23:45
https://www.dji.com/downloads/softwares/dji-assistant-2-consumer-drones-series
A vision sensor calibration cannot be done with this software and the Mavic 3 (unfortunately). Correct me if I'm wrong...
2022-8-31
fly.overflying
Tornado12 Posted at 8-31 04:37
Thank you for your feedback. It was a little late end of the day and yes getting dark. I will try this afternoon during daylight and update here.
2022-8-31
Tornado12
fly.overflying Posted at 8-31 08:04
Then it was most certainly due to low light. You would have been given a notification on the screen about it though - pay attention to those red notifications in the top left of the fly app screen. You need pretty decent light for the sensors to function properly.
2022-8-31
TonyPHX
Flight distance : 11229610 ft
Paladin, I would hope you are aware that Assistant 2 does not have a vision sensor calibration feature currently.
2022-8-31
fly.overflying
Tornado12 Posted at 8-31 10:24
After testing today during the day I can confirm that the obstacle avoidance sensors works! I am extremely happy to finally hold a DJI drone without any issues. Below is a video of first fly!
2022-9-2
