aoe2paladin
Flight distance : 1823077 ft
iPad Pro 11" (USB-C connector)
-- Connecting cable direct to the aircraft allows you to access videos using the Files app, can play or transfer direct from aircraft to iPhone / MacBook using AirDrop through iPad
-- Connecting cable direct to the goggles 2 does NOT allow you to access videos using the Files app, if aircraft is powered on DJI Fly app states "file preview through mobile device not supported on current aircraft"
-- Connecting cable direct to goggles 2 and running LivePreview during flight will cache a low quality copy of the goggles video on the iPad, can view / save after turning aircraft OFF
iPhone 13 Max (Lightening connector)
-- Connecting cable direct to aircraft does NOT power the aircraft flight controller, no file access in the Files or DJI Fly app
-- Turning on the aircraft still does NOT allow file access
-- Connecting cable direct to goggles 2 and running LivePreview during flight will cache a low quality copy of the goggles video on the iPhone, can view / save after turning aircraft OFF
MacBook Pro 16" (USB-C connector)
-- Connecting cable to aircraft creates two folders in Finder (SD_CARD, INTERNAL)
-- Connecting cable to goggles 2 does nothing, have to pull SD card
It seems there are pretty big inconsistencies between Avata firmware and previous aircraft, almost like the Avata firmware was rushed out and they would add these common features in later
-- Other aircraft can preview album via DJI Fly app, but not Avata
-- Older Goggles V2 can tell the aircraft to record h.265, but not the newer Goggles 2 |
