Gimbal Tilt not responding
3072 9 2022-9-11
RichfromHowellNJ
Flight distance : 508255 ft
Using the Motion Controller on the DJI Avata, I notice that the tilt on the gimbal works but when I come back to land it does not respond which forces me to take off my Goggles to maks sure I'm landing where I want to land.  Has anyone had that experience.  I'm running the latest firmware on the Motion Controller, Avata, Goggles 2 and Avata Battery.  Any insight would be most appreciated.  Thank you.
2022-9-11
RichfromHowellNJ
BTW, this thing is SO much fun to fly!
2022-9-11
Team Geezer
My gimbal control switch works well on the ground, both before and after I arm the motors. But once the aircraft takes off the gimbal switch is inoperative and the motion controller controls the gimbal tilt. I can hover near my intended landing spot and fly the drone downward and it will stop 0.8' above the ground. I can then land it using the lock button.
2022-9-11
RichfromHowellNJ
Team Geezer Posted at 9-11 08:53
@Team Geezer .... thank you for the insight.  I'm going to give that a try.  Seems like the tilt button should work all the time so I'm not quite sure why they even have it.  Thanks for the tip!
2022-9-11
Team Geezer
Yep! I agree. The gimbal tilt should work all of the time. It does on my 2S and my antique DJI 450.
2022-9-11
RichfromHowellNJ
Team Geezer Posted at 9-11 10:14
Well maybe in the next firmware update
2022-9-11
Buzzyone
Flight distance : 4647913 ft
RichfromHowellNJ Posted at 9-11 09:55
Tilt function is disabled once the drone takes off, same as the FPV.
2022-9-11
Team Geezer
Is it also disabled when using the remote controller? It makes it hard to shoot video from a downward perspective while in level flight. It would be nice to be able to enable/disable it.
As it is, the gimbal switch on the motion controller is useless. Who needs it if the drone isn't in flight?
2022-9-11
djiuser_kyCggVWPXvfM
Team Geezer Posted at 9-11 11:57
Use the head tracking for this Geezer..  You can fly with motion straight and look down for a better shot
2022-9-11
Team Geezer
djiuser_kyCggVWPXvfM Posted at 9-11 14:55
Thanks. I guess that's a work around. I'll practice holding my head a just the right angle for the duration of the shot.
2022-9-11
