JJB*
Flight distance : 12445630 ft
Peadar_911 Posted at 9-13 08:16
Had a look at the logs and the first issue with being far from Home Point makes sense. On the second log I could see that the Home Point was updated further down the hill, but altitude was still showing -23m. I did another test today on a similar hill, Home Point updates OK, but the altitude does not, it still showed a negative reading. I couldn't bring the drone down to eye level, but by holding the stick down for several seconds it went into landing mode and I was able to stop it and catch it before it hit the (very rough) ground. Seems strange that updating the HP does not reset the altitude to zero.
HI,
first issue far from HP....does not make sense to me. HP has nothing to do with the ability to a normal landing.
It is not normal to update HP on its own....flying lower than take off position shows as a negative number.
Resetting HP by you does not change the zero reference height, baro height is set to zero at takeoff, will not change during flight.
Flightlog might explain why the HP was reset in flight, if not done by yourself.
cheers
JJB |
