fly app
870 11 2022-9-16
1966romeo
Flight distance : 322421 ft
Norway
I am trying to innstall Fly app on my samsung Galaxy tab a with Android 11. It dont want to innstall. Can anyone help me.  Please
2022-9-16
DJI Stephen
Hello there 1966romeo. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to install the DJI Fly application ( https://www.dji.com/dji-fly ) to see if the issue will still persist? If the issue persist kindly please try using a different recommended mobile device for us to be able to isolate the said issue. Thank you.
2022-9-16
Chrislayeruk
Flight distance : 96811 ft
DJI Stephen Posted at 9-16 20:54
[view_image]
I cannot get the DJI Fly app to work on my Motorola G7 Power running Android 10. It just tells me the app keeps stopping. Totally useless right now. That’s a shame… as I can’t use the quick transfer on my iPad either…
2022-9-17
Merlin1951
Flight distance : 276434 ft
I just purchased a Samsung Galaxy A13 5G phone (runs Android 12) and transferred all my apps to it from my old Galaxy S8+. I tried running DJI Fly and it immediately stopped and went back to my home screen. Thinking maybe the transfer went bad I deleted it and tried the transfer again. Same result. I then uninstalled the app and tried to install it from the Play Store. Play Store said DJI Fly is not compatible with my phone. I then went to the DJI download page and downloaded the APK and tried to install that way. The installer informed me the app was not compatible with my device (see attached). I need an update or a patch that fixes this problem as I can't fly my drone.
2022-9-17
1966romeo
Norway
[view_image]
I have it innstalled on my Samsung s22, its working fine. But i want to innstall it on the tab. I want to use a bigger screen when i am flying my mini 3.  Sending u 2 screen shot.
2022-9-17
1966romeo
Norway
I am sorry if you dont understan the language, its Norwegian.
2022-9-17
DJI Stephen
Chrislayeruk Posted at 9-17 08:50
Hi there Chrislayeruk. I am sorry for the trouble this has accused and thank you for reaching out. After checking the mobile device ( Motorola G7 ) that you are using on the DJI Fly application. I am sorry to say that the mobile device is not yet recommended for the DJI application. DJI suggests using a recommended mobile device for the DJI Fly application for compatibility and reliability purposes. There is a possibility that the Motorola G7 will be able to work on the DJI Fly application. But however, since it's not yet optimized with the said DJI application we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Fly application while using it. For reference I will post a link where in you can check the recommended mobile devices for the DJI Fly application ( https://www.dji.com/downloads/djiapp/dji-fly ). Thank you.
2022-9-18
Chrislayeruk
DJI Stephen Posted at 9-18 22:05
Thanks for the information, luckily I don’t need it to fly the drone. I was hoping Quick Transfer may work with it, as it won’t work on my iPad Pro…
2022-9-19
djiuser_ESUavwIbhTpf
Brazil
[view_image]
I was using the app normally but then after an updating I was no longer able to use it . I have a Motorola g7 plus power and my drone is a mini mavic se , I have uninstalled and installed several times in the DJI website but nothing works
2022-9-19
Merlin1951
So, DJI recommends going out and spending hundreds of dollars for a compatible device instead of fixing the software. And you call that good customer support?
2022-9-19
Merlin1951
You might try contacting tech support via online chat and see if they have a fix. If not, they can inform their developers and hopefully get a fix for you.
2022-9-20
fans0a85b3fb
Norway
Merlin1951 Posted at 9-20 06:41
Have tryed, the only thing they say is to down load from Dji.com and innstall!!!!!!!!! HAve done that lots of time! Thank god its working on S22, if not i woud not be abel to fly. But i want to have a bigger screen. Maybe Dji Want me to buy a new Tab??????!!!!!!
2022-9-20
