After Linking RC to P4P, Didn't have option to Activate drone or.
974 4 2022-9-19
fans345b22a5
Flight distance : 172569 ft
I recently purchased a used P4P (done only; not controller).  I used my spare P4P RC controller to sucessfully link to the drone.  However, I was never given the option to Activiate the drone or provide a Device name.  Within the DJI GO 4 app, I manually entered a device name in the available input field, and then conducted the initial flight test.  Drone flew fine, but the device name did not appear DJI GO 4 App in the Flight Records, and hence, there was no flight record for the initial flight.   Obviously, I think I need to somehow "Activate" this drone.  Can anyone help?
Thanks,
Kevin
2022-9-19
DAFlys
Used drones dont require activation,  thats only needed once when new.
2022-9-20
DAFlys
2022-9-20
fans345b22a5
Many thanks for the quick response and clarification regarding "activation".   Also, the issue I was experiencing with the flight record not being saved in the DJI GO 4 app was "fixed" by simply re-naming the device to an existing name that was already included in the Flight Records.  Subsequently, the flight record was indeed saved.
Many thanks,
Kevin
2022-9-20
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. If you purchase a 2nd hand DJI aircraft, the Activation process will no longer be available as the aircraft can only be activated once or if the unit is brandnew. We are also glad that you managed to isolate the issue with regards to your flight records. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support.
2022-9-20
