Mavic 3 Cine camera and SSD no longer recognized by aircraft
1380 6 2022-9-20
barnytj
Flight distance : 18343698 ft
Tanzania
I am currently on an assignment with my Mavic 3 Cine in Northern Tanzania.  Until this morning it has worked flawlessly for several months .  Footage from yesterday was copied overnight.  This morning, after being taken out of its hard carry case and switched on I noticed there was no camera display at all, and camera settings were not there.  It I go into the “about” page on the RC pro it lists the camera serial number as N/A.
Has anyone else had such an issue before?  It has not had any crashes or hard landing landings and has not been dropped.   Thanks in advance.
2022-9-20
CloudVisual
Flight distance : 97545420 ft
I would plug it into a PC and open up DJI Assistant and see what it's saying. You may have to flash the firmware and see if the problem persists.
2022-9-21
barnytj
Tanzania
Assistant 2 does not detect the Mavic 3 and the computer doesn’t see the SSD any more..
2022-9-21
CloudVisual
Sounds like a serious hardware failure then. Nothing to do but raise a ticket with DJI. I hope you've got another drone to carry on your filming...
2022-9-21
TonyPHX
Flight distance : 11229610 ft
Something is broken.
2022-9-21
DJI Stephen
Hello there barnytj. I am sorry for the trouble this has caused and thank you for reaching out. Since we are having this issue with your DJI Mavic 3 and have done several troubleshooting steps to fix the issue and still the issue persist. It would be best to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do our best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2022-9-21
djiuser_m2lUsskXqZ0T
Flight distance : 653550 ft
South Africa
Hi, did you manage to overcome this issue? I'm experiencing the same issue and I am in the middle of a project assignment as well.
2023-4-28
