DJI Paladin
Hi there. Thank you for reaching out and we do apologize for the inconvenience. Kindly please refer to the statement below for you to identify if your battery is swollen.
1. Put a battery on a flat table. Slightly touch the battery. If the battery vibrates, it indicates that the battery has swollen.
2. Place a ruler or hard card on a battery cell for comparison. If an obvious gap is visible, it indicates that the battery has swollen.
3. Slightly press the battery cell position. If it can be pressed in and appears in a balloon status, it indicates that the battery has swollen. If the position is hard and flat, it indicates that the battery is normal.
If you could send us a short video showing your battery that would be very helpful for us to check it here on our end. Hope this helps. Thank you for your valued support. |
