New DJI P1 Firmware Released (04/26/2023)
3759 10 2022-9-27
DJI Support
Flight distance : 2408 ft
Overview:
  • Release Date: 2023.04.26
  • DJI P1 Firmware: v07.00.01.10
  • Firmware Upgrade Method: DJI P1 - SD card / Update All in App
  • Other Product Firmware and Software Required:
M300 RTK aircraft firmware: v06.01.01.00
M300 RTK remote controller firmware: v06.01.01.00
  • DJI Pilot 2 App Android: v6.1.2.3
What’s New?
  • Fixed issue where the camera cannot stop taking photos when pressing the shutter button in Timed mode after frequently switching between Timed mode and Video mode.
Notes
  • After updating to the latest firmware version, the user cannot downgrade to v04.00.02.05 or earlier.
  • Make sure that the aircraft firmware, remote controller firmware, DJI P1 firmware, and DJI Pilot app firmware are updated to the latest.
Overview:
  • Release Date: 2022.09.28
  • DJI P1 Firmware: v04.00.02.05
  • Other Product Firmware and Software Required: M300 RTK aircraft firmware: v04.01.00.00
  • M300 RTK remote controller firmware: v04.01.01.01
  • DJI Pilot App Android: v4.1.1.14 (M300)
What’s New?
  • Added support time synchronization and position compensation when using with the DJI DL 24mm/50mm F2.8 LS ASPH Lens.
  • Fixed issue: HMS prompts lens infinity focus is not calibrated after Infinity Focus Calibration is performed by the user.
  • Fixed issue: the AWB difference is too large in some scenarios.
Notes
  • After updating to the latest firmware version, the user cannot downgrade to v03.00.01.04 or earlier.
2022-9-27
Frontliner 2020
Philippines
Thanks dji...
2022-9-28
Amed
Flight distance : 2214019 ft
Turkey
Where will the files be downloaded from? Not on their site
2022-9-29
DJI Natalia
Amed Posted at 9-29 02:04
Hi, there.
Please use this link to update to the latest version: https://www.dji.com/zenmuse-p1/downloads
Besides, if there is anything else that we can help with, please just feel free to let us know.
2022-9-29
mikes1
Flight distance : 1740699 ft
Has DJI released the 24 and 50-mm lenses for the P1? I see it's part of this firmware update.
2022-10-2
Craig_Tas
Flight distance : 2998255 ft
Excellent!
2022-10-2
Arnor
Flight distance : 2660509 ft
Belgium
mikes1 Posted at 10-2 13:24
Or does it mean it supports the Zenmuse X7 lenses?
2022-10-7
AtkinsDronesUK
Is there any support for top mounting the P1 onto the M300 -  At present - it has a few glitches -
1) the image recieved to the Smart controller is upside down.
2) - if you enter the gallery to check an image, when you return to the main feed- its blank.
The second of these doesnt happen if it's on the lower gimbal connections.
Will it ever be possible to set a custom white balance?
2022-10-10
julangdamar
Flight distance : 511388 ft
Indonesia
i have update my m300 to latest firmware, and i have an issue about "continue" option in out of control action menu was missing. anybody can help me? the continue option for my work so important cause my operation area have bad signal
2022-11-1
julangdamar
Indonesia
i have update my m300 to latest firmware, and i have an issue about "continue" option in out of control action menu was missing. anybody can help me? the continue option for my work so important cause my operation area have bad signal.
2022-11-1
Ryan H.
Is the 16mm X7 lens supported as well? Is it necessary to update the M300 firmware for the 24mm lens to work? It seemed that some were having success before the P1 firmware update, and the 12/5/2022 update sounds like it has been a nightmare which I would like to avoid. Thank you, Ryan
2023-1-30
