New DJI Transmission Firmware Released (9/29/2022)
4520 15 2022-9-28
DJI Support
Flight distance : 2408 ft
Overview
  • Date: 2022.09.29
  • DJI Video Transmitter Firmware: v01.05.0100
  • DJI High-Bright Remote Monitor Firmware: v01.05.0100
  • DJI Video Transmitter User Guide: v1.0
  • DJI High-Bright Remote Monitor User Guide: v1.2
What’s New?
  • Added support to use the remote monitor with the DJI Video Transmitter.
  • Added function to turn off the screen display of the remote monitor by pressing the power button once and function to lock the touch screen by pressing the power button twice.
  • Added webcam function to the USB-C port on the remote monitor to upload audio and video streams from O3 Pro video transmission system to a computer.
  • Added support to mount the hand grips to the remote monitor for firmware updates.
  • Added support to control the gimbal and camera on Ronin 2 and RS 3 Pro using the hand grips.
  • Added function to set the HDMI/SDI output frame rate of the remote monitor expansion plate automatically according to the input image frame rate on the video transmitter.
Notes:
  • Make sure to update both the video transmitter and high-bright remote monitor to the latest firmware version when using them together. Otherwise, the video transmission may work abnormally.
  • If the update fails, restart the device and try again.
2022-9-28
Frontliner 2020
Philippines
thanks dji...
2022-9-28
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2022-9-29
Fred Fred Fred
Flight distance : 4512966 ft
Thanks for the info.
2022-9-29
Papaxiclas
Flight distance : 5455981 ft
Portugal
Is te already possible to record on the screen?
When will the expansion plate be on stock?
2022-9-29
DJI Natalia
Papaxiclas Posted at 9-29 09:16
Hi, there. Sorry for the late reply.Hope the following details can help you:
1. If you want to record, you can check the below information:
1). Please try to install the Micro SD card into the Micro SD card slot on the right side of the DJI image transmission highlighter;
2). And please connect the DJI Image Transmission Highlight Monitor to the DJI Ronin 4D/DJI Transmission, and click the circular icon at the bottom of the screen to enable the recording function.
2. We did not receive any relevant information about the expansion plate, you can stay turn to our official website to get the latest details.
Thank you for your support.
2022-9-30
WOODTV
why isn't audio embedded in the SDI output of the bright monitor?
2022-10-5
Taszz
Flight distance : 25633 ft
In the manual it is written that you can also see the battery status of the transmitter on the screen.
It's not visible on my screen. Only the battery status of the screen
Is this a setting?
I use the DJI batteries
2022-10-8
djiuser_eNXqOyywcMv4
Flight distance : 3937844 ft
This new RC controller does not do what advirtised to do on mini 3 pro. I feel I was ripped off. This has less distance the the ocusync 2.0. I hope they will correct this. This was my second DJI drone and distance is not good at all. It was unabstructure and only a 10th of what DJI SAYS IT WILL DO.
2022-10-8
djiuser_UavE5sPrOCXp
I ordered the transmission in Europe, testet it with my account - now I am in the US for a production, but I can not change the monitor into the FCC mode. I tried everything, installing the software again,... how can I achieve the transformation to the FCC mode??
2022-10-11
jjmedia
Flight distance : 3356 ft
Is there even a way to change from CE to FCC? I tried installing and activating the software with VPN set to USA but still locked in CE mode.
2022-10-21
djiuser_10yaSYpUZydt
Flight distance : 459741 ft
Austria
Just bought Action 3 and webcam work fine. But why there is no possibility to zoom in?
With at least 2x zoom the scene would be much more natural
2022-10-24
fansfdb3dc36
My DJI Assistant 2 doesn't allow me to update...
2022-10-25
fansfdb3dc36
Hi There, Im having issue updating the firmware on the transmitter, anyone else having this issue?
2022-10-27
SubPro
Flight distance : 1150180 ft
"Added support to control the gimbal and camera on Ronin 2 and RS 3 Pro using the hand grips." with Firmware update v01.05.0100
How do I connect the Ronin 2 to the DJI Remote Monitor?
Its not working right? Only Ronin RS3?
2023-2-15
ricerick3
Ukraine
Oh thank you, finally.
2023-3-1
