Sean-bumble-bee
Flight distance : 15997 ft
I use 1.4.8 for the mini 2 without a problem........but.......you may need to download your flight logs from the current version to a computer etc. and KEEP THEM THERE. Then uninstall the old app and then, using a computer or the phone's file browser, remove the residue of the old FLY app file system including the logs in the 'new' (post 1.5.something?) storage area for flight records. I might have done this with one phone but I can't remember for certain. I would be concerned that the post 1.5.something file structure might interfere with 1.4.8..
I do remember that in earlier versions there was an issue where any logs created by the newer version could not be transferred to an older version otherwise none of the logs on the old version were visible in the in-app flight 'replayer'. I think that occurred around 1.2
The above said I am not sure if my firmware is up to date so do not know if I am on 2022 firmware. But if you have backed up the flight logs to computer and if a roll back to 1.4.8 fails, you could always reinstall a newer version and then copy the logs back to the appropriate place.
I use a pre 1.2 App for my mavic mini.
Of course this only applies to Android devices, I know of no way to roll back Apple devices.
