Labroides
Flight distance : 9991457 ft
Startup Posted at 10-12 06:40
Thanks for the reply!
Can you tell me the theory behind this? Like is it like a car is less efficient when being driven fast so the battery uage is less efficient in sport mode? Or have you just found this to be true in actual use?
Apart from numerous tests that have confirmed what I said, ......
The drone has to tilt to fly forward.
This directs more thrust to forward propulsion and less for holding the drone up.
To fly faster, the drone tilts more and has to spin the motors even faster to make up for the loss of vertical thrust.
When flying fastest, at max tilt, the motors are working very hard to maintain enough vertical thrust and overcome air resistance. |
