DJI Mavic Pro fails to update firmware: undefined 0x032800
514 2 2022-10-16
TobyWanShinobi
My drone's camera will not work, and says firmware update required. I try to update via the DJI GO 4 app and the firmware update fails.
So I've tried to update the Mavic Pro and the controller via the DJI Assistant 2 about 12 times now and it continues to fail to update. Downloads the update, transmits it, then fails around 40% or so.
I get the error: undefined 0x032800
This is very frustrating to have a $1200 piece of equipment stop working because it requires an unnecessary firmware update. The drone was working perfectly fine before DJI forced this update.
I've read quite a few forum posts about this and it sounds like I need to send my drone and controller in for repair.
Thank you,
Jon
2022-10-16
TobyWanShinobi
Not sure if this posted... it says "draft"
2022-10-16
DJI Susan
Hi there, sorry to read about this issue. Please try to back up the files from DJI GO 4 app, uninstall the DJI DJI GO 4 from your phone and install it again from https://www.dji.com/downloads/djiapp/dji-go-4 and then try to update the firmware again.
Besides, may I know which version of the DJI Assistant 2 you are using? Please try to remove the DJI Assistant 2 from your computer and download it again from https://www.dji.com/downloads/softwares/assistant-dji-2
If the error persists, please send the drone back for further diagnosis and service.
Please click https://www.dji.com/us/service/repair to start an online repair case.
2022-10-16
