DJI Natalia
Hi, there. Sorry for the late reply.
For the transmission distance, the control mode can connect up to two monitors. If the broadcast mode is turned on, multiple monitors can be connected.
For the signal, you can use the DJI high-bright remote monitor to check whether the environment you are currently using has a lot of interference and whether there is a lot of occlusions.
Besides, please note that the fan cannot be turned off, because the machine itself will generate a large amount of heat during operation, but we will forward your feedback to the relevant team and see how we can do better in the future.
Thank you.
